Regardign AR800V.v 3.0.. WLAN problem :(
  • Thread starter Thread starter Kiranreddy
  • Replies Replies 20
  • Views Views 23,042
Kiranreddy
BSNL
:pleasehelp:Hello all..I'm new to this forum. Please help me in solving this problem. Few days back I took BSNL Broadband connection with AR800V v3.0 modem (Type II, in BSNL Terms). I'm not able to browse even the google page if i connect my laptop in Wireless connection, even though it says signal strength is excellent. My friend told me to change the DNS address, still the problem persists. Adding to this, upload is much more faster than download (visible in utorrent). Whats the reason for this. BSNL people are not responding even after many compliant through call center (1504). This is new type of modem and this is not updated to call center people. So, please help me in solving this issue.Thanks and Regards, Kiran Reddy.
This may be similar to some Linksys/D-Link models.
We need at least the screen shots of the modem menu pages
to help you.
1.
upload the connection status and Device info page
at TinyPic - Free Image Hosting, Photo Sharing & Video Hosting and give the links here.
At company's website no manual or screen shot/s available.
2.
When you connect the laptop in wifi mode,
Does your network show secured or Unsecured ?
Have you used a security key ?
3.
Post this data COPY/PASTE for laptop in wif mode.
Start run type cmd OK
new window
type ipconfig /all
4.
Can you surf the Internet in LAN mode ?
I work with bsnl customer support just give ur land line num i ll assist you online....and 1 thing first make sure whether its working thru the LAN cable first...:cool2:
BSNL provided a new modem(AR800V v3.0) to me(Bangalore). It only worked for a week time. The "DSL" led light on the modem is not glowing. I had connected all the cables properly. I can only able to browse the modem(192.168.1.1). I can see "DSL Status: Not connected". Can some one help me to identify what could be the problem? I googled to check the configuration details with no luck.If I connect my old ADSL broadband modem, I am able to browse the Internet. Looks like there is no issue on the telephone cable. Please help me..
Even in Google search we don't get any details. Any manufacturer name ? adsl modem+4 Lan port + wifi Need device Info page screen shot.Save as a jpg picture . upload at tinypic.com give the link here.or post Advanced options ADSL page./ connection status etc. See the "STICKY" post in BSNL Forum wa 3002-g4 quick reference
Dear All, I have also taken up a BSNL connection with AR800v V3.0 modem. I could not set up the wireless network itself with this modem. The BSNL service engineer has told that there are some laptop settings to be changed, which she is not aware of... If any one could help me out on how to configure Wireless internet with this modem, it would be of a great use....I have already enabled "wireless On" setting in my laptop. Im not sure of the settings in 192.168.1.1 modem configuration page. currently, im getting a message that " Select a certificate or other credentials for connection to the network BSNL_AP(SSID) Please support, Thanks, Amudhan
Hi, please find the same.... please support after checking this screenshots....
Modem connection stauts:
Modem configuration page 1
Modem configuration page 2
System Network configuration settings
CHANGE country to INDIA
Select channel 11
In security settings
scroll the options select unsecured.
Save apply.
Now your wifi network will be unsecured.
For testing only tis is done.
Now try for wifi connection.
( You can create a new Wireless LAn connection
for unsecured key . open )
Para two ;
POST the DEVICE status of the modem/router.
feedback.
