Reliance JioFiber: Port Forwarding NOT SUPPORTED
  • Thread starter Thread starter spacer
  • Replies Replies 189
  • Views Views 116,647
The JioFiber router web interface presents option for port forwarding however it does not work in practice.
The page accepts and saves all the configuration changes you do. Yet you won't be able to connect to the port from outside.
The router also has a DMZ and UPnP options and those do not work either.
Customer care is unable to help ("We have no information about this at the moment")
The IP address as seen from outside is different than what the router shows as its WAN IP. So the router is not directly exposed to the internet. It is behind a NAT/Firewall.
The IP the router sees is 100.XX.XX.XX
IP as seen by sites like whatismyip.com is 49.XX.XX.XX
As far as I know 100.XX.XX.XX is a public IP but trying to access that IP from outside does not work either. So the router is sitting behind a firewall.
This is a major limitation if you want to run any kind of server. So developers and gamers beware.
If you want to make your DVR internet accessible, you can't.
With JioFi (dongle) you could use internet accessible IPv6 address to eliminate need of port forwarding but the Jio Fiber router only allocates local IPv6 addresses. Even if IPv6 worked like JioFi, it would not solve problem for IPv4 connections. So there is no alternative at the moment. You can use a VPN, but it slows you down and has other limitations.
I was planning to discontinue my old ISP but due to this limitation, I might have to discontinue JioFiber instead.
@sayangr what will that achieve?
Jio let you forward upto 3 ports for CCTV monitoring, seach this thread for more info.
This is old information. I have successfully forwarded 5 ports by contacting Customer care. There does not seem to be any hard restriction on number of ports forwarded. However, if you ask them to forward 100 ports, they will refuse obviously.
How do I figure out what is the pingable ip from outside without talking to customer service?
Customer service has mapped three port fwds but didn't bother giving me the public ip to test.
I understand it's not the wan ip on the router or the public ip from whatsmyipaddress.
Jio CS is painful to reach even for basic questions.
You cannot ping these public IPs. Make use of a DDNS service, to make note of any changing IP address on the WAN side.
In case ports are opened by jio customer care then how would we connect, lets say use remote desktop, over internet. What will be the ip address that one would have to connect to.
@mahesh1283 call up their support and ask them the IP address and port number which they have forwarded. The engineer who visited told me that information which he got from backend team.
@mahesh1283 No. That is Jio’s port forwarding server with fixed static IP address. This is not port forwarding technically. It is Port Mapping from Jio's end. It is one way incoming traffic useful for CCTV or Remote Desktop access and cannot be used for bittorrent port forwarding.
@tatyasky so incase you need to remote desktop from outside the network are you able to use this static ip address?
For example lets assume
1. Static ip address given by jio customer care is 101.102.34.45.
2. Port opened by jio customer care is 3000
3. Target home pc lan ip address is 192.168.21.55
4. Port open in home pc for incoming traffic is 4000
Then what will be your port forward settings in jio router port forward setting page?
Can you please also tell me the process to apply for portforwarding and static ip request?
Is it done informally over phone?
Or do i have to write a email to customer care for this?
Also how long does it take for them to open ports and communicate it to the customer?
