Reliance JioFiber: Port Forwarding NOT SUPPORTED
  • Thread starter Thread starter spacer
  • Replies Replies 189
  • Views Views 119,201
The JioFiber router web interface presents option for port forwarding however it does not work in practice.
The page accepts and saves all the configuration changes you do. Yet you won't be able to connect to the port from outside.
The router also has a DMZ and UPnP options and those do not work either.
Customer care is unable to help ("We have no information about this at the moment")
The IP address as seen from outside is different than what the router shows as its WAN IP. So the router is not directly exposed to the internet. It is behind a NAT/Firewall.
The IP the router sees is 100.XX.XX.XX
IP as seen by sites like whatismyip.com is 49.XX.XX.XX
As far as I know 100.XX.XX.XX is a public IP but trying to access that IP from outside does not work either. So the router is sitting behind a firewall.
This is a major limitation if you want to run any kind of server. So developers and gamers beware.
If you want to make your DVR internet accessible, you can't.
With JioFi (dongle) you could use internet accessible IPv6 address to eliminate need of port forwarding but the Jio Fiber router only allocates local IPv6 addresses. Even if IPv6 worked like JioFi, it would not solve problem for IPv4 connections. So there is no alternative at the moment. You can use a VPN, but it slows you down and has other limitations.
I was planning to discontinue my old ISP but due to this limitation, I might have to discontinue JioFiber instead.
Those linked site servers are not a proper test for IPV6 as its just testing the basics. The correct test can only be from outside the JIO network.
Those test always passed for me.
Try hosting something on ipv6 like a webserver and connect from outside the Jio network - If the page loads then only we can be 100% sure.
Port forwarding RDP is a bad security practice. Checkout Remote computer access over the internet using RDP, what could go wrong??
I would suggest a VPN or RDP gateway like Apache Gaucamole for accessing PCs remotely.
I have to agree forwarding 10 ports for RDP is risky especially for the office network. Ensuring your Windows Machines are always patched and uptodate is not easy considering how many security flaws are found on Windows weekly /monthly.
Just looking at Apache Gaucamole , it requires it to be installed on a server first correct ? which would mean at least one system being online all the time?
Probably a VPN would be the best option here but then again his router should support either open vpn or ipsec vpn or host it on a raspberry
pie device
I still feel the zerotier option is the best one here as no forwards needed , its end To end encrypted and no overhead of bandwidth due to vpn plus it’s free and source code is available on GitHub if one needs to understand more
  • Like
Reactions: a.c
So I tried by hosting a xampp server on my laptop and was able to access it through my Airtel 4g!
I can also ping through my 4g net. I tried accessing web server through port 80 and 443, both worked.
Proof:
That site servers are outside your network and if they can ping your ip then your network is accessible from web and certain ports may be blocked by your firewall which those site will not test. You can use other sites to check open ports.
Testing from airtel 4g doesn't make any sense.
I can confirm now that IPv6 on jio fibre does work.
The reason this did not work for me before was that I had set the IPv6 firewall rule to disable during my tests on forgot to turn it on.
Thanks Ankush for pointing to the IPv6 firewall rule which needs to be added for all traffic
Tested with Xampp web-server on Mac OSX and connecting from outside Jios network just to be 100% sure.
@Smh you are right that the site servers are outside the network but in my test with the firewall rule not in place it still showed ALL oK on their website. Hence I wanted to be 100% sure by hosting a website and connecting to it from outside
Hey, I just thought of adding something. You may install softether VPN server on any home PC (Raspberry Pi should work, I haven't tested). Then install softether VPN client software on your remote PC (doesn't work with android/iOS). They use UDP hole punching to traverse through NAT firewalls and absolutely no port forwarding is required. They do use a 3rd server to establish that connection but once the connection is established, it is a direct connection between the home network and remote PC. So, latency and bandwidth are great. Use the DDNS they provide. Also, if this fails, they also have a free Azure server to relay your connections (they say this connection is totally end to end encrypted, but I don't use this.). Connect into your local network and use whatever you want (SSH, plex server, CCTV) on your home network as you would at home.
Thanks @keithcardozo for taking out time and making a detailed post. Suggest just this standalone post should be stickied
I am surprised that they replied/looked into email. I sent some 3-4 emails for DVR port forwarding and never got answered by them over email.
Only multiple calls to customer care worked! I never knew we could get only 3 - I had asked for 2 and got same.
May be in future will ask once more.
PS: Do they bind port forwarding to mac address?
How does one make a post stickied ? I am not sure how to
