setting up a wi-fi switch/hub
nightwolf2k5
local welder/Lobotomist
b-s-n-l
ok.. well.. i have a comp and 2 laptops at home.. n.. i'm pretty tired of plugging n unplugging the ethernet cable again n again.. (the clip's broken cuz of this)... so.. i was wondering..1. is it possible that there is a wi-fi switch/hub out there so that i can connect my laptops and my comp together (wireless with the laptops and with a wire for the comp).2. if it is available.. how much will it cost and will i be able to go online on it using more than one computer?3. i use multiple accounts.. can i switch between accounts like the way i can do in bridged mode?
Netgear's WiFi costs ~2k. And you can use net on multiple PCs at the same time.You should be ablt to use multiple accounts by using PPPOE
i think bsnl offers wireless adsl router on rent too at some additional 20Rs. check their website.
