Slow speed on BSNL Broadband
  • Thread starter Thread starter karumudi7
  • Replies Replies 8
  • Views Views 8,970
karumudi7
AIRTEL
I recently got the BSNL connection (Hyderabad-Kukatpally). 2 days back they gave the BB connection.
My plan is H500C
I checked the Speed , it is in between 300kbps-400kbps. But while I was using the same plan in my town(Ongole) I got >1.6Mbps.
Here the line is also new one (New copper wire).
How can I overcome this?
Just done the Speed test. Upload spedd is very high than Download speed.
Modem SS:
---------- Post added at 06:38 AM ---------- Previous post was at 05:47 AM ----------
After seeing the Post @ https://broadband.forum/bsnl-broadband/61397-50-kbps-speed-too-slow/
He mentioned SNR ratios and Line Autentication, I got as follows:
SNR (Downstream) 6.95 dB
SNR (Upstream) 7.5 dB
Line Attentuation(Downstream) 11.5 dB
Line Attentuation(Upstream) 6.5 dB
SNR is bad and Line Attentication is Good.
How can I solve this and got the SNR to 30db?
Ask the line man to check your line. May be too many joints. Check yourselves. The line from junction box to your home.
From the pole box to my home it is a Single Direct wire. No joints.
Low SNR means poor line condition. Nothing we can do. Complain to Senior Divisional Engineer (SDE).
Hi
I am in BSNL 750 UL plan, havin 2 MBPS free for the frst 15 days. Here is the result from speedtest
https://www.speedtest.net
But torrents are not downloading more that 50-60k , any pointers guys ? My current Modem is Linksys AM300 Annexe A, which is connected to Linksys VOIP (vonage) device, which connects my pc and net
DSL Status
DSL Status: UP
DSL Modulation Mode: Auto
DSL Path Mode: INTERLEAVED
Downstream Rate: 2042 Kbps
Upstream Rate: 862 Kbps
Downstream Margin: 31 db
Upstream Margin: 10 db
Downstream Line Attenuation: 11
Upstream Line Attenuation: 4
Downstream Transmit Power: 12
Upstream Transmit Power: 11
LOS Errors: 0
PVC Connection
PVC Status: UP
Encapsulation: RFC 2516 PPPoE
Multiplexing: LLC
Autodetect: Enable
VPI: 0
VCI: 35
You need to use good torrents. Seed to peer ratio should be high. Try torrents from private trackers.
