Vultr - Looking Glass Can you try downloading the 100MB file from here, see what speeds you get.
If you're facing low speeds on wifi, you'll have to buy a router. Some Netlink (the kind in your screenshot, they're sold in different names) ont have really slow wifi. Mine can only give me 16-20mbps. Using an old D-LinkADSL modem as AP gave me 50mbps. LAN is fine.
Here's some things you can do:
1. Make sure your side is all correct, try changing MTU size from the earlier posted link.
2. Restart the ONT, worked for me once after keeping it on for a week.
3. You'll have to call BSNL.
