Slow speed problem on Reliance Jio Fiber wireless router
  • Thread starter Thread starter Shubham
  • Replies Replies 117
  • Views Views 36,098
Getting only 50 mbps on morning and 93 mbps at evening.
tested on 5ghz and through lan cable,
is this because of peak hours??
Or they throttling the speeds??
Check speeds from 8 pm to 12 pm since these are the peak hours.
No issues here on LAN cable. Earlier I had a problem with 2.4 GHz band so shifted the rest of the devices on 5 GHz band, looking fine to me as of now.
Jio throttles speed once you reach 95+ Mbps, you will never get full 100 Mbps.
You can never expect the full bandwith as advertised by the brand because you to need to include the TCP overhead loss which for Fibre can vary b/w 5-6% of the allotted bandwith. For a 100Mbps plan the best you can expect is 94-95mbps. For you to get 100mbps, Jio needs to set the profile allotted bandwith at 106Mbps.
Even i am getting low speed. One thing i noticed that unpeered content is having issue. Speed varies between 20-30mbps
for peered servers speed is fine at around 95 mbps
Speed to international speed test servers is 20-30 mbps.
This issue is random and sometimes i get full speed even to unpeered servers
Use this Thread for the Slow Speeds on LAN. (Strictly LAN tests only. WiFi Tests are stupid)
I don't want to make a mixture of WiFi and LAN.
