varkey
I got banned!
I have couple of Huawei HG8120C ONTs for sale. The model has the following ports
You can also clone or modify the serial number and PON password if required so that you can easily replace your existing ONT without any changes from the LCO or BSNL.
The units are brand new and imported from China. To reduce shipment weight during import, only the bare units were imported, so this does not include the box and the power adapter. It uses the standard 12V power adapter with barrel type 5.5x2.5/2.1mm connector. Any power adapter rated higher than 0.5A will work just fine.
The price is Rs 1750 shipped (Delhivery)
Note :I have several units for sale, will update the thread once all units are sold out. Until then it's available One unit left ALL SOLD OUT
PS : If your existing ONT is Alphion or if you are procuring the ONT to use with an Alphion OLT, this unit will NOT work. Alphion OLT only supports Alphion ONT.
PS : I am not associated with the forum other than being a regular member, have no association with the forum's owners/moderators and they are not benefiting from any of these transactions nor are they responsible for it.
- 1 GE port
- 1 FE port
- 1 TEL port
Note :
