Speed issue
  • Thread starter Thread starter manasgta
  • Replies Replies 22
  • Views Views 4,046
@manasgata.
Your IP will change everytime you login and disconnect.
checkip.dyndns.com:8245/ ( add http etc)
See post No 8 and give feedback.
Mention modem model too.
Check speed Sydney server at speedtest.net. ( add www. )
give link showing data.
>Result from Sydney server
https://www.speedtest.net
>By I.P 59.~ i meant that the people have on new ports have I.P address 117.~ but i am still on an old one.
>I downloaded DrTCP but i dont actually know what to do with it and neither with the open DNS settings.
@srickymember manasgta on Home 500C Post No 1 ( speed upto 2 Mbps)@manasgta. DRTCP. simply click default values . Save and RESTART computer. Recheck speed.Feedback
Problem: Low speed for two years :now Home 500 plan.Modem Ut300R2u ( suspect ?) IP 59.xx.xx.xx1.speedtest.net/result/321661695.png mumbai D/L 501kb/s ping 122ms. sept 11th2 speedtest.net/result/327782592.png sydney D/L 399kb/s ping 1006ms sept 23rdConsulted DR TCP. default "diet" LAB CHANGED ?!3speedtest.net/result/328177129.png Lahore D/L 426kb/s ping 1031ms sept 24thPara two:RxTest again at mumbai server. Addl Info needed : : ADSL status showing snr/attn/linespeed /mod selected etc.4. Post screen shot of modem page or only above dataselect Statistics/ADSL in modem menu. 5. OS used. updated ?6. Ipconfig/all: Start RUN type cmd type ipconfig/all
:(Mumbai test results:
:(file:///C:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg
:(O.S - Windows XP service pack 2
:(ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : home
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : VIA VT6105 Rhine III Fast Ethernet A
dapter
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : ASL-25020
Physical Address. . . . . . . . . : 00-00-00-FE-69-9C
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.4
Default Gateway . . . . . . . . . : 192.168.1.2
DHCP Server . . . . . . . . . . . : 192.168.1.2
DNS Servers . . . . . . . . . . . : 192.168.1.2
Lease Obtained. . . . . . . . . . : Wednesday, September 24, 2008 1:18:4
5 PM
Lease Expires . . . . . . . . . . : Saturday, September 27, 2008 1:18:45
PM
PPP adapter DataOne:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 59.96.162.253
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 59.96.162.253
DNS Servers . . . . . . . . . . . : 218.248.240.79
218.248.240.208
NetBIOS over Tcpip. . . . . . . . : Disabled
:(Is it safe to share the ipconfig info on the forum?
DrTCP default values have not made any appreciable change.
TCP/IP properties
Change to Obtain Ip address automatically.
Network/LAN/properties TCP/IP properties.
In DNS enter 208.67.220.220 and 208.67.222.222.
Test speed again at mumbai server. report speed only. no screenshot required.
Para two : You can blank or delete the physical address.( called MAC ). Rest of the information can be shown.
Para two :(1) Seems you are using USB port for Internet connection .
(2)can you try ethernet card connection ? Connect RJ45 cable to VIA...... ethernet card port.
Start/AllPrograms/Accessories/Communications/Network connection Wizard
follow instructions.
Ref :1.VIA VT6105 Rhine III Fast Ethernet Adapter
http://www.soft32.com/download_180740.html
2.UT300R2U USB driver/s
http://www.calcutta.bsnl.co.in/dataoneinstall/usb04.swf
i used to connect through ethernet card previously.A few days back it stopped working properly,i connected to the internet but after some time a message is displayed "Local Area Connection has limited or no connectivity" and i get disconnected.So i started using USB.I have also re-installed USB drivers.
@s.ricky
How come u get 2mbps speed on a 256 kbps connection?
@manasgta Modem no change.Reconnect ethernetcard. Disconnect USB Cable.Post Ipconfig/allStart/Network/LAN Properties.Status/repair/support. give results.
