if someone was to invest in
ubnt wireless hardware, which model would you recommend.
Depends on floor plan.
2880 square feet house I think. Basement, Ground Floor and First Floor. Since I have a corner house, I have access to the complete side of the house. I would prefer to install something on the ground floor that should cover it completely in addition to hopefully first floor and basement as well.
A floor plan of the place could help, but off hand looks like you need 1 AP-
AC-LR on each of the 3 floors. Nothing would guarantee coverage across floors, you may try putting one on the ground and see how the signal strength on below & above floors.
so it needs a device like
pi with controller configured to be running 24x7?
For home use, you can set it up on a Pi, some
NAS models also support installation of the controller, any PC or
MAC, but it does not need to run 24x7, if you do, you would have granular control of your wifi, you can even restrict bandwidth of clients from the controller. They even have a cloud key, it is just like a thumb drive sized with one LAN port and runs the controller 24x7.
You may even setup the APs individually using the mobile app, I prefer the controller mode. The AP does not have a web interface, it is like enterprise models (Zebra/Aruba etc) and needs a controller to be configured & monitored. Once you use it, I can guarantee you would never go back to consumer grade equipment.
that's not a big deal. i use a regular computer. desktop computer. and then i have a pi that runs pretty much 24x7. wifi at home is pretty much set right now. i just have a
mi router in the basement and an extender on the ground floor. first floor is not covered much but it was not a priority until now. i was just wondering if i could get an estimate on how i can make it a proper
mesh network so that devices do not lose internet when they switch from one network to another.
With consumer grade wifi, we setup individual APs and they work in isolated manner, but with controller, we just need to setup the controller software and adapt the APs to replicate the config. All the APs work in tandem to each other, does load balance among bands & APs. The wifi network is a single unified network managed by the controller using multiple APs. Thus, maybe start with 1 AP on ground floor, and expland on other floors if required. Later you may disable the wifi from you MI router.
EDIT:
Another product they have recently launched for homes is the Amplifi
AmpliFi Wi-Fi
It is not available through dealer/integrator channel in India, so no warranty support and you would have to import. But I like keeping the routing & wifi functions separate.
