Hi All,I have got Tata Sky in 2 of my tvs but initially i did not opt for 3rd connection as that is in my computer... wanted to check if anyone of you is using Tata Sky with Computer TV Tuner card... i have an external TechCom TV Tuner...Guys, please tell me if it will work with it?Thanks a tonUdit
QUOTE(hitman @ Mar 5 2007, 01:22 PM) [snapback]82186[/snapback]
I have both internal and external tv tuner card... Tata Sky works with both of them....[/b]
I guess you used the composite A/V input in your tv tuner for TataSky input? How have you set up your tv tuner to change the channels?
No... currently I am using tht antenna option only... I don't have tht audio cable for composite A/V input so tht's y using antenna option...Tv tuner card have just set the channel 68 and I use Tata Sky remote to change channels... i don't think we can change channels from tht tv tuner card remote... can we ?
QUOTE(hitman @ Mar 6 2007, 11:54 AM) [snapback]82284[/snapback]
No... currently I am using tht antenna option only... I don't have tht audio cable for composite A/V input so tht's y using antenna option...Tv tuner card have just set the channel 68 and I use Tata Sky remote to change channels... i don't think we can change channels from tht tv tuner card remote... can we ?[/b]
Sorry but I think i am a bit confused at the moment. As far as I remember, TataSky set top box, gives output only via the A/V cables. Normally, we connect these to the TV, and the set TV to AUX input to see TataSky. How are you receiving TataSky in your tuner card via antenna cable?
hmm, ok then I missed seeing this interface on my STB...but, even if you are using coax output from the STB, it would still be emitting only a single channel, like from the A/V cable, not everything, like on a regular cable tv cable, right?Also, as far as i remember, my Thomson STB came only with A/V cables. DO you need to buy coax cable separately? Any quality improvements on using it?
I got coax cable with my humax box only..... I think one get better picture and sound quality by using AV cables... but since i don't have tht cable (with 3 points at one side and 1 point at other) so I am using the coax one... the av cable i got with my stb have 3 points on both the sides...
HiI am buying set top box from local cable operator...i just want to know can i record the programs from the box to my pc(i am tv tuner card) can you suggest what equipment i have to use if want to scheduled my recording..please reply me Thanks
