anurag.choudhary
Hmm..MPEG 4 is actually inferior quality compared to MPEG 2.
Strongly Disagree
What actually is happening behind the scene is this ->
MPEG-2 enabled DTH broadcasters are transmitting data on arround 1.5 Mbps to 6.0 Mbps, and at the same time MPEG-4 is broadcasting data on 0.9 Mbps to 2.3 Mbps.
MPEG-2 broadcasters are spending almost twice more than that of MPEG-4, and still giving a comparable picture quality.
Think a bit what will happen with picture quality if MPEG-4 is broadcasted on 5 Mbps.
viz. 128 Kbps mp3 is said to be CD quality but actually CD quality is far better than MP3's encoded at 128 Kbps
Every compression technique is lossy (lossy = where you will loose some part), that is why it is known as compression. Compress a CD to 320 kbps and listen to it...
i know my cable is gonna suck on a 40'' tv....So i need a DTH for better quality....i belive Sony television upscale video to an extend. if that fixes the pixellation problem i would be happy... who knows all manufacturer give a hype about their products and the consumers suffer....
Sony Bravia is the best!!! no doubt about it, The temporal Noise Reduction which Sony is using in their LCDs is the best so far.
Strongly Disagree
