Torrenting Problem on Spectra
@potlu213 try seedbox it's dirt cheap to try practically free if 4gb is okay for you but I think it won't be
And u can get an 8gb space (unlike the normal 4gb)
On the mobile app sonicbit.
If u need to know about how much torrents could be qeued and what would be their up/down speed,
you can check up thier website.
sonicseedbox.com
well guess what, spectranet is definitely the worst ISP in this country right now!
i used a seedbox for trial purposes and then tried to download that file to my PC via a FTP client (Filezilla). To my shock, i was downloading the file at only 15-20 kbps speeds. i changed ISP to hathway to test & guess what - full speed of the connection.
these MFers are even throttling FTP speeds! its not just limited to torrents. how can they do this and get away with it?
guys, never take a connection from spectra shit.
tbh no idea. all seedboxes do tend to showcase support for both https and ftp 🤔
haven't used one personally. which one are you testing? free account has https download support?
ok i m confused now - i just added the files back & i just did a right click -> process queue - & now suddenly its downloading at awesome speeds which my connection has!
its from .seedboxws.com. i think i ll tinker around some more with it but this seems to work and its very cheap too. not a bad option at all if it works on this crappy ISP.
