  • Featured
  • Replies Replies 208
  • Views Views 66,852
Username: ONTUSER
Can you share steps for enabling bridge mode after unlocking the router?
I am able to reset, unlock, lock again with default config, hard reset etc but after enabling bridge mode on port 4 or others the LAN connection does not get established.
@Rajneesh Rana
I will share the steps what I have done so far to enable the bridge mode.
1) Unlock the router to gain root access.
2) Hard reset the router from the back of the router by holding the pin for approx 30+ seconds.
3) Manually added the pppoe configurations in Network --> WAN to enable the internet connection.
4) Now go to Network --> LAN and enable the bridge mode on port 4 and restart the router.
5) Connect the port 4 of the Nokia modem to your second router WAN port via lan cable.
6) In your second router go to WAN settings, add the pppoe configurations similar to what you've entered in previous steps including the vlan id.
7) After saving the pppoe configs your second router will authenticate with airtel backend server and fetch a new ip address.
If the above steps are not working for you then try these steps with a different router or you can also dial up pppoe connection via your pc to check if it's working or not, but remember to change vlan id in the device manager first.
Bridge mode for me didn't work until airtel enabled it from their end even though my ont was unlocked.
Maybe the guys who have it working got it enabled before they unlocked.
Tried these steps once again
All these worked, manual WAN setup on router works but after enabling Bridge mode on port 4 there's no link connection on the bridge port.
Still stuck at this.
