  • Featured
  • Replies Replies 167
  • Views Views 55,826
Username: ONTUSER
@Rehan ahmad I am getting the below error can you help me with this Please
Traceback (most recent call last):
File "C:\Users\xxxx\OneDrive\Desktop\Nokia-router-cfg-tool.py", line 119, in <module>
cf = open(sys.argv[2], 'rb')
FileNotFoundError: [Errno 2] No such file or directory: 'config.cfg'
Copy the config.cfg file into the directory which has the script, and then run the script with -u config.cfg
<LimitAccount_ONTUSER rw="RW" t="boolean" v="false"></LimitAccount_ONTUSER>
<CLIPrompt ml="256" rw="RW" t="string" v=""></CLIPrompt>
<DebugDyPass. n="DyPass" t="staticObject">
<Enable rw="RW" t="boolean" v="false"></Enable>
<PriKey ml="256" rw="R" t="string" v="MHcCAQEEIPFhltfHR9VfP7FzyghlodH7Vdrz341haJgLMREeejoAoGCCqGSM49AwEHoUQDQgAEiD2Krd2pb+t5hfqqOF3k1JEz+TIYA7EdLcHRjk0qv85umsCJSejJ"></PriKey>
<PassLen dv="8" max="44" min="6" rw="R" t="int" v="8"></PassLen>
</DebugDyPass.>
Could someone please assist me in unlocking the Nokia 2425-G as described above, but then showing the ONTUSER password as incorrect?
Hey @Rehan ahmad ,
Can you help me to configure the bsnl internet with Airtel GPON modem ? i got the pon indicator working after changing the serial number in Airtel gpon to that of Netlink serial number. But still no internet and Somehow authentication is failing.
<TelnetSshAccount. n="TelnetSshAccount" t="staticObject">
<Enable rw="RW" t="boolean" v="False"></Enable>
<UserName ml="64" rw="RW" t="string" v=""></UserName>
<Password ml="64" rw="RW" t="string" v=""></Password>
Can you tell me what to change here? do I have to change "64" or something else?
I am unable to login . whenever i try to login via telnet it shows following error-
Login fail count since last successful login: 3
### login ####
AONT login: ONTUSER
Password:
####Login incorrect
Login incorrect
I am typing password correctly though it says Login incorrect. Please help
