Very Slow Speed From 2 A.m To 8 A.m
  • Thread starter Thread starter ayan4u
  • Replies Replies 42
  • Views Views 10,070
All rubbish folks, check your line for interference and noise. Ask your exchange to check the line for minute frequency distortions. Dont pull your wire on top of power cables.Rest all is fine with BSNL no speed latency etc. Good speed. Enjoy!!
haha...i agree with mayflower...i'm getting good speed from link-removed..except that i have to wait for about 10 min to get the nodes and seeds info updated..but after that everything works fine... :thumbsup:
Yes I am too facing this problem since last 10 days .. BSNL call center 1500no use .. call exchange .. I say that during daytime it works fine .. then what happens at 2 to 8 ?
BSNL Tamilnadu subscribers may try this site for booking their problems.. I remember using this when I had Dataone and received callbacks from my exchange too :o ...
@essbabe... yeah... but it worked for me... I'm from Coimbatore and I guess as the other STD codes are present that might be for entire T.N. (Might exclude Chennai as it was a diff. telecom circle before)
I hope I am not repeating it.. if you check the dataone tarriff table
there is a row saying
Particulars Tariff in Rs.
Home
UL 900
PLUS **
Home
UL 900## Home 250
Home 500
Home 1000
Home
1800
Home
3300
Night Unlimited (0200-0800 Hrs)
No Yes Yes Yes Yes
that means, (if most of the people are aware of the 2-8 unlimited DL rule).. most of the Limited-plan ppl schedule their download during that time window..
and hence is what you experience...
Only this makes sense to me and is kind of implied from that row in tarrif table..
***in fact I was about to ask abt how it works out ( 2-8 unlimited) and then i stumbled upon this thread.. So that kind of answers my question too..
hope this helps.
akshay
sorry for the bad format, looks like the forum post cudnt handle table -copy paste.. but u can always refer to the original table here
Bharat Sanchar Nigam Ltd.
I am on home 500 and i get good enough speed on torrents between 2 am and 8 am. The only site that slows me down is link-removed. So no problems here.:yahoo: Btw i will change to plan 750 as i have high usage.
