whitestar_999
Regulars
whatever you do between 2-8AM is free(meaning both upload & download).it is advised to login at 2:05AM & logout at 7:55AM to avoid the issues of excess billing.if a download starts before free time but ends into the free time,say,1:55-2:10AM,it will be charged.make sure to match your system clock with bsnl as bsnl's own clock timings will be used to calculate bill.just match your system clock with some indian news channel(i used AAJ TAK).after that keep a 5 min safety limit like the times i mentioned before(2:05 & 7:55AM).
if you use pppoe mode(in which you get connected by just turning on the modem)you must restart the modem at the above mentioned times.
if you use bridge mode(in which you enter your bsnl username/password in windows to connect) then no need to restart the modem.just connect at 2:05AM & disconnect at 7:55AM.
