Yeah I've seen all the press releases being printed about free broadband in India in 2009 and I'll believe it when I see it.
The point I was making is that even if they do provide it their network will just slow everyone down. You'll get 2Mbps speeds inside BSNL's network (I'm being optimistic here) but they do not have enough international bandwidth to give 2Mbps to everyone.
What u can say can be compared to group of computers in a LAN connection...
if that is the case we should get 8mbps (or even more)................... now
now u r inter linked with another BSNL customer But even if u download any thing u will be charged that make me amazing
that is not the case they each server is directly connected to major ISP's of world ..
its easy to get 2mbps line for international network ....
Even Bsnl has got some satellites for Broadband purpose u just can ignore that ..............
They have set target of providing internet to Rural Areas every place in india ( through Wi-Fi)
VisualRoute traceroute: connection test, trace IP address, IP trace, IP address locations
check this site u can check u server speed
I will tell u what i got ...
then Again I tested
u can see the ping time(ms) there it is less than 10 ms every time when connected with London (last Server) to NIB Delhi the difference is not more than 30ms
If u have such less ping time between the server the netspeed is so high that deals with more than 100-1000 mbps
Bsnl is offering that speed for your normal servers that we use (home use)
In day time they r leased for Corporate Offices .....
At night every one will get 2mbps even they say 1:20 ratio ......
Even speed Doesn't vary (mostly contains 2 mbps )
Don't take Bsnl is a Low ranked ISP .........
Now Bsnl is thinking of using this servers or home use only ..................
