mundle2002
For the FM band with the centre frequency of 98 MHz, we have to first calculate the wavelength by the formula:-wavelength(in meter) = speed of light(m/s) divided by frequency (in Hz).therefore, wavelength = 300000000 m/s divided by 98000000 Hz. = 3.06 meters.The length of the antenna should be some multiple of the wavelength. This is because the antenna must present itself as a resonant circuit to the RF signal so as to maximize the power in the antenna.It can be either 1/4th wavelength = 75cm as those used in Radios.It can be 1/2 wavelength = 1.5m (a dipole)or a full wavelength.You can download the pdf of the article "Mosfet based amplifier for FM radio DXing" from the website of "Electronics for you" magazine.Although i used the antenna design from the article, i didnt use the circuit.I used the circuit from the article "FM booster". You can also get the same circuit from the website You can also design a Yagi antenna:-Length of dipole = 1.5m.Length of reflector = approx. 5% larger than dipole.Space between dipole and reflector = 0.2*wavelength.Length of 1st director = approx. 4% smaller than dipole.Space between dipole and 1st director = 0.12*wavelength.Make the 2nd director by decreasing 4% length as compared to 1st director,make 3rd director by decreasing 4% length of 2nd director............and so on.................you can add as many directors as you like.The inter-director spacing will be 0.12*wavelength.Although the Yagi antenna is a little bit bulkier and prone to breakage by the birds sitting on it, it will definitely give a greater gain compared to any other antenna.
