@/members/mcx/
see the circuit given there. Whether copied from Popular Electronics, or an American web site or EFY makes no difference. Theory is same. But nowadays very difficult to get electronic parts for home construction.
https://broadband.forum/fm-radio-stations/24979-fm-radio-reception/
Your FM radio tuned circuit is for 88 to 108 MHz.
The bandwidth allowed in the IF usually 10.7 Mhz with a narrow B/W
for B/C audio.
So no possibility of local
TV station breaking through. even if you use a untuned RF amplifier.
assume your TV audio FM signal say 67.75 round it to 67.7
When you tune 88 MHz the L.O will be 88+10.7= 98.7 MHz
When you tune 108 MHz the L.O will be 108+10.7 = 118.7 MHz.
So TV FM audio cannot generate the 10.7 MHz IF.
98.7 minus 67.7( approx) IF 31 MHz
118.7 minus 67.7( approx ) IF 51MHz.
You can check this. A local FM say 108MHz will be heard around 88MHz also.
108+10.7=LO 118.7 Normal 88+10.7=98.7 LO (image)
signal 108 mixes with 98.7 to give reception when dial shows 88 MHz
i think u r not much familiar with cable tv technology.
More the different signals at the booster input, more the mixing of different frequencies. Check the filters of adjacent channel tv modulators & their mixers. If the filter is not attenuating -60db of adjust channel audio & video, it is getting over. This is not the place to go more in detail.
I hv done the market survey also. I got the info that at many places they get tv sound in the fm channel. They are using vhf boosters. Hence we hv decided to go our own way. Developing proper fm booster.
