@mcxIn electronics never commit to any definite answer! (* conditions apply!)If the Input and Output impedance is matched maximum energy is transferred.( Thevenin's theorem)Yes . Should be some improvement.Also when you try a Yagi antenna the impedance is not always 50 ohms, and goes lower and lower with increase in no of elements !.Actually RG 8u ( thick cable and costly ) is better than RG58U. We also work out loss in signal strength ( attenuation) for the cable length used. The longer the cable more the loss!Finally trying different combinations, the final improvement in reception is what matters .IGNORE: beyond this thread subject. For reception , not critical, but for transmitting , we take extreme care not to damage the VHF transmitter's output stage. . ( Another test instrument SWR meter used and an Antenna tuner, either automatic or manual with coil, condenser tapped combinations).
