I am using Beam Internet connection with speed of 1 mbps in Hyderabad. I will upgrade to 4 mbps or 10 mbps by next month.
My Objective is to share the Beam Internet through wireless/Wifi to my Android/BB Phones and ethernet to desktop.
At present I am able to connect only one by plugging in directly the RJ45 of the Beam cable to the ethernet port of PC.
what is the hardware/Wireless Router that i have to buy..... Am using the desktop which is not wifi capable .
will there be a problem to configure wireless router with desktop pc which is not wifi capable . If yes , how do i solve it???
Am not tech savvy...... am little poor in tech words...... and suggest me wireless routers under Rs. 1500/-.........
The Beam broad band connection procedure:
Connect the RJ45 jack to the ethernet port of the computer.
Open the broser.
A dynamic IP gets assigned to the computer and a login screen pops up where we enter the uesr name and password.
Thanks
abrams
Open the broser.
Thanks
abrams
