How to connect Beam cable Broadband to a wireless router
  • Thread starter Thread starter jagdish_p
  • Replies Replies 61
  • Views Views 105,604
spot on !!!
thanks for the help :)
Yeah this thing will work work as the router can Auto detect your internet connection type
Congo, For how much?
bought it for 2850/- from babosa computers suggested by ranjit...
thanks ranjit
You are welcome cha_indian I have seen this router go for cheaper by a hundred bucks but its for the non B1 version and some retailers are selling the B1 version for a bit more though, you got it for a good price.
Any report of having wifi mode with Beam BB connection ?
Use any Standalone wifi router such as Netgear wgr614v9,
( select Dynamic IP), connect Beam Rj45 to WAN port.
Connect another Rj45 from LAN1 to desktop. Log in.
Set up wifi as usual. wifi should work.
feedback needed.
I would like to report to you all that my router was not working properly with the supplied firmware version 2.0.1.1 and also 2.0.2.0 so i gave it to rashi thinking that there was some problem with the hardware.... they have installed the firmware version 9.0.2.4b . with this version automatic login is working fine but i still cannot use the download master feature... i am still not sure whether i should go for DD-WRT firmware ...
