BSNL blocks port 5060
  • Thread starter Thread starter srini_ca
  • Replies Replies 4
  • Views Views 5,360
srini_ca
BSNL
Does BSNL blocks port 5060? I am trying to set up VOIP soft phone x-lite client, but port 5060 has been blocked. Has any faced similar kind of problem? I have BSNL 256 KBS unlimited plan in Chennai.
What is blocked outgoing or incoming port? If its incoming then u can easily use any other port but if its outgoing then u will have to use proxy of VSP
It is possible ..they did block 5060 outgoin afew months ago..on an experimental basis..besides they have installed new software to block VoIP and subversive websites..there is a thread on that somewhere on this forumHowever it may be a configurational error on part of topic starter
Actually it's more likely not a configuration error (a simple telnet to port 5060 will be enough to confirm) I have had the same VoIP port blocking problems a few weeks back at Hyderabad. It may be some IP address ranges or done selectively/once in a while. But during these periods, alternative ports given by the VSPs get around these issues (eg. VoXalot: 2060, 3060 & 4060, VBuzzer: 80 etc.)
Kris
