BSNL broadband: Can't access websites while using a PPPoE connection
  • Thread starter Thread starter LiNkEr
  • Replies Replies 122
  • Views Views 108,944
@anand_bsnl/a 14digit portal ID with password as passoword. If your IP is 117.xx.xx.xxContact your exchange.
Hi essbebe,
I am unable to open some sites like yahoo,gmail,hotmail,naukri&google (upto now).I tried changing MTU from 1500 to 1492&1454..still my problem didn't get fixed.I also tried giving static IP & DNS(which are recommended by you).I also tried changing my modem..still the problem persists.disabling AV & firewall... all possible troubleshootings I have done still no use....Actually I want to know what is "opendns"..? how we will do that..? even my google is not working to google it...Will reinstalling my OS will fix the problem?
ipconfig/all details :
Windows IP Configuration
Host Name . . . . . . . . . . . . : ankur-b5d731307
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : D-Link DFE-520TX PCI Fast Ethernet Adapter
Physical Address. . . . . . . . . : 00-17-9A-0C-A7-7F
Dhcp Enabled. . . . . . . . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.10
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Saturday, September 06, 2008 1:50:43 AM
Lease Expires . . . . . . . . . . : Saturday, September 13, 2008 1:50:43 AM
PPP adapter bsnl BB:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 117.195.225.19
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 117.195.225.19
DNS Servers . . . . . . . . . . . : 218.248.255.146
218.248.255.139
NetBIOS over Tcpip. . . . . . . . : Disabled
My PC details:
O.S. - Windows XP sp3
Modem - UT300R2U(connected in bridge mode)
AV- NOD32 smart security
/members/khanna16/ Modem UT300R2U
Mention your modem model . see below
1Check DNS page and enter Opendns given below.
Start/Network/LAN/properties/TCP IP
2check Obtain IP address automatically.
3In DNS enter 208.67.220.220 and 208.67.222.222
( you can enter BSNL DNS as alternate ).
Para Two :
PPP adapter. Same: TCP/IP properties Advanced look under WINS
select check/enable Default for Netbios over IP.
Subnet mask 255.255.255.255 doubtful. How you entered it ? I think end entry is 254.
Default Gateway usually the IP address of modem viz 192.168.1.1 and Ip address will be different . say 192.168.1.11 etc ( depending on the range you have entered in modem/router)
REF: calcuttatelephones.com/dataoneinstall/menu.html Select your modem.
There are two models.
see
Hi essbebe,
I have done all what you said.. but didnt work. I thought my problem should be with my PC. So I tried reinstalling OS and it worked.
But I am really happy with your fast replies and all. I really appreciate your help..
members/khanna16/Thanks a lot for the feedback. Really appreciate , you remembered to post a reply for benefit of other users.Don't forget to update the OS !Difficult to tell users to check their computer system/OSin this forum.Assumed to be perfect!
hello .. im unable to access few sites like bwtorrents / dctorrents, rest all other are working fine. i've tried using the methods mentioned here but cannot get access to sites. i can certainly ping the site & getting response also but the browser keeps on saying .. connecting .. connecting to 123.com / abc.com
I'm having the same problem. Sites like bwt and wikipedia and this site don't open, but when I reboot the router I'll be able to access the above sites, but not others before the reboot and the same vice versa when I reboot again. I've checked if I get the same problem on another computer and another account and it's the same. Something's really screwed with bsnl...
^^I am using opendns. The lookup seems fine, it just says connecting and then "cannot connect to this page."
