Mention modem model/make. Start .. select RUN...... type cmdnew page opens .......type ipconfig /allcheck Default Gateway.If it is 192.168.1.1 that is the modem's IP.If the page opens and you can type userId ( for the modem default usually admin )and password ( usually admin or password)and modem gives an error message, PW might be in error.You have to RESET the modem (a switch or access hole) in the back with power on for about 20 to 30 seconds.Modem settings will revert to Factory settings.
Am having WA3002G4 Model No reset button found on the Router i wanna 2 go back 2 Automatic Mode pls help me outi can able 2 connect the net in bridging mode
Follow the instruction and let us know if it solves your problem...Go into modem setup from browser (192.168.1.1, admin/admin)Click Advanced Setup> WAN SetupClick "Edit" on First Row showing 0/35 under VPI/VCI column.Uner ATM PVC ConfigurationVPI: [0-255]=35VCI: [1-65535]=35Enable VLAN Tagging = do not selectService Category: = UBR without PCRclick nextSelect "PPP over Ethernet (PPPoE)" and Encapsulation Mode = "LLC/SNAP-Bridging"Click NextUnder PPP Username and PasswordPPP Username: = PPP Password: = PPPoE Service Name: = Leave this BlankAuthentication Method: = AutoDo not select anything else on this page.Enable NAT = yesEnable Firewall =yesEnable IGMP Multicast = yesEnable WAN Service = yesService Name =pppoe_0_35_1 (or anything else)Click nextNow "WAN Setup - Summary" should look like thisVPI / VCI: 0 / 35Connection Type: PPPoEService Name: pppoe_0_35_1Service Category: UBRIP Address: Automatically AssignedService State: EnabledNAT: EnabledFirewall: EnabledIGMP Multicast: EnabledQuality Of Service: DisabledClick "Save".Click "Save and Reboot" on next page**Restart your PC and WA3002G4**
Are you connected by USB? Then try 192.168.1.2If not, goto Start, Run, type 'cmd', enter, in the command prompt type 'ipconfig /all'. Under Ethernet adapter 'Local Area Connection' check the value for Default Gateway, try that IP in your browser.
