in your modem settings look for line rates & post their values here.also you must use a download manager like flashget to download from
microsoft not the plain downlaod as you posted before.
Equipment Vendor ZTE
Model No ZXDSL 831AII
Chipset Part No ZXDSL 831AIIV1.0.1i_D18_IN
Chipset Version No E.37.7.37
ADSL Port Enabled
Downstream Line Rate 1021 kbps
Upstream Line Rate 510 kbps
LAN IP Address 192.168.1.1
Default Gateway not currently set
Primary
DNS Server not currently set
Secondary DNS Server not currently set
Firmware Version ZXDSL 831AIIV1.0.1i_D18_IN
System Up Time 1 day, 0 hour
today u will get updated check the speed once i have moved form h 500 to ul 1350 ......... i got the 2 mbps form 1 st august to yesterday 11.58 pm that was soo good
I just called BSNL broadband department.. they told me no one got their plan changed yet, there is some issue with this and it will get sorted within 2-3 days. The plan change is showing in the bbservice, but the status is showing as OPEN. :wall:
https://broadband.forum/bsnl-broadband/32297-i-am-extremely-happy-bsnl-ul-1350-a/#post220048
Did you try OpenDNs 208.67.220.220 and 208.67.222.222 ?
U mean to put these in primary & secondary dns?
I haven't done that yet, whats the use of using these dns settings?
