ACT Speed less after plan Upgrade
Deepak Singh
Guntur AP
ACT Fibernet
I recently upgraded my ACT plan from 50 mbps to 100 mbps when I was on 50 mbps plan I use to get constant 6.2 MBps which is 48 mbps speed on ubisoft downloads
after plan upgrade I am getting around 10 to 10.5 MBps on same servers which is around 80mbps speed. I also brought gigabit lan router in that its showing internet speed as 100mbps. If max speed supported is 100mbps how ACT is providing 150 mbps plans. What I have to do to get more speed
It may be due to bottle neck between you and server.Anyway you are getting 80-84mbps which is good speed.You may be given cat 5 that is the reason for 100mbps max speed.You would be given cat 6 if your speed is more than 100mbps.Anyway you seem to reside in guntur and i am also from guntur.How is act service in your area.I was disgusted with act service and customer support and shifted to bsnl from the past 6 months and downtime is around 30mins.Hope act fibernet service is good in your area.
I also thought that lan wire cold be the problem so I used my cat 6 cable but still connection speed is 100 mbps.
I think the port is of 100 mbps speed will ACT upgrade the if we ask. ya ACT is good except when there are wire cuts.
Good to here that u are also from Guntur
Its not my pc or router problem both are showing 1gbps. I am talking about the connection between act box and my router is 100 mbps. because its 100 mbps i am getting 80 mbps. How can act give 150 mbps on 100 mbps port or can I ask them to change the switch
I Tried with Cat 6 Cable so port may be 100 mbps. I called Customer Care he told that all there switches support full speeds they provide.
Have you plugged your PC directly to ACT Incoming cable and tried getting a link ? What is the link speed ?
