BSNL VMC AN1020-21(Detailed Visual Guide)
  • Thread starter Thread starter S.INDIA
  • Replies Replies 77
  • Views Views 143,245
Thanxxx alot..!!!!!after a long time I am able to connect my lappy with wifi..I owe my thanxx from the bottom of my heart and would like you to help others on internet thru this media so dat every1 fels benefitted
Is This Work For the iPhone? I Have an iPhone 2G (3.1.3) but i cant connect it with Wifi. i have BSNL Broadband with VMC AN1020-21 Modem. When ever i connect it shows "Unable to join the Network". My iPhone works with other modem like Netgear. Please help me if u can...Replay n thnx in advance.
Refer guide. Check Channel number selected 6 or 11
1.
You should connect to BSNL Broadband In "Always On" PPP/PPPoE mode
USERID PW entered in wan page of modem.
2.
give a range say 192.168.1.2 to 192.168.1.10
In LAN page enable DHCP
3. Enable UpNp if seen
4. Check wifi works in laptop.
5. same ssid will appear in phone.
6. Enter security key , if any. used.
feedback.
uncheck adsl2+ Recheck snr/attn data.
it has increased but d problem remains....should i change d modem...?earlier wired type1 modem used to work gr8..
Hii..
Thanks for the info..
but i want to know how to use USB Port of modem
win98-lan-usb
download drivers first and save to Harddisk.
Then connect to usb Port the modem.
Let Windows deteect New Hardware etc.
Upload the ADSL or connection status page and give link here.
