BSNL VMC AN1020-21(Detailed Visual Guide)
  • Thread starter Thread starter S.INDIA
  • Replies Replies 77
  • Views Views 143,245
wats d speed diff in lan and usb??which one is faster?
Data transfer depends on speed of your broadband connection.
lan data transfer upto 100Mbps and USB (OLD) 11 Mbps.
compare usual WIfi 54 Mbps/108 Mbps.
Lan mode preferred .
Click Network /LAn Status and see the speed specified.
i tried every thing as explained above but the problem still persists ....the internet through Ethernet is working fine but through WIFI i cannot connect to my HP laptop ...i done understand if it is my modem or my laptop problem ...my laptop is HP and i use windows7 OS....help me out ...
You mean to say you can use more than one system simultaneously using ethernet cable ?Can you see the WiFi network in your laptop's " wireless connections " ?To do1. Configure your modem in PPPoE mode.2. Enable DHCP in your modem.3. In the TCP/IP properties of your connection (both PC and laptop), set " Obtain IP address automatically ".
no iam now using the ethernet connection for my laptop and now i want to make it wireless ans my modem is teracon and it supports wifi
i used a name WIFI and it appears and when i click the connect option itz not connecting ..
