Hi,I am having BSNL connection UL plan.My connection is fine with desktop but i have added it as preferred network in Wireless on my laptop.I add and it shows ok but when i try to refresh my list it doesnt show up BSNL network?What can be the problem is it from drivers?Kindly help?
configure your modem/router with pppoe,dhcp enable,disable all the security nable broadcast SSID and configure your laptop for get ip address automatically ..now delete all the wireless connections and refresh you wireless networks.you will find your routers SSID now connect using it.if your modem's ip is 192.168.1.1 you laptop shoud get ip addressh as 192.168.1.X , default gateway 192.168.1.1 mask 255.255.255.0 208.67.222.222 and 208.67.220.220 as dns.try this.
