Configuration for VOIP/SIP calls( using Zoiper/GS Wave) on Huawei ONT and TP Link Router.
  • Thread starter Thread starter AARON NASH
  • Replies Replies 97
  • Views Views 31,724
First, I want to thank @varkey for this ONT(HG8120C).
This configuration thread is mainly for Huawei ONT with TP-Link routers.
For configuring other ONT brands like DBC, Syrotech, Netlink and for more details you can view @sloj's thread -FTTH VOIP SIP Softphone configuration with ONT/ONU. (Now works on some more apps) | BSNL Bharat Fiber Broadband
Configuration for Ont and Router
For configuring you need to get the following details from Bsnl/LCO.
  • For Internet
  1. VLAN ID
  2. Username
  3. Password
  • For VOIP(static)
  1. VLAN ID
  2. IP Address
  3. Subnet Mask
  4. Default Gateway
  5. Primary DNS Server
  6. Secondary DNS Server
  • FOR SIP ACCOUNT
  1. Regist/Auth User Name- 91<stdcode><telphone number>
  2. Password- 0000 or last four digits of the telephone number
  3. Sip Server- 10.187.6.12 (kerala)
Log in to ONT's Web Interface
1.Create a wan profile for internet using the credentials provided by Bsnl. ( Wan - WAN Configuration - click on NEW)
2. Create another wan profile for VOIP-Internet.
3. Configure VoIP details. ( Voice - VoIP Basic Configuration)
4. Check the status of Wan profiles and VOIP. ( Status - WAN Information - VoIP Information)
5. Enable SIP. ( Network Application - ALG Configuration)
6. To ping the sip server, we have to create a Static Route. ( Route - Static Route Configuration - Click on new )
Note- 1. Gateway is the same Default Gateway asked in Voip wan profile.
2. Do not enable Default Route.
Go to Routing Table, to check the new Static route.
7. Ping Sip Server using Ping Test from Ont. ( System Tools - Maintenance)
8. Log in to your TP-link router ( archer c6) and enable Sip. ( Advanced - Nat Forwarding - ALG)
Note - Those who have D-Link routers might have to disable sip in order ping the sip server- Why won’t my VoIP device work with my router?
9. Ping Sip server from your PC/Laptop.
Configuring Zoiper 5 on PC/Laptop using Windows 10.
1. Add Username/login - 91<stdcode><telphone number>
Password - 0000 or last four digits of the telephone number
2. Add Sip server, port no and also add outbound proxy( same as sip server).
3. After testing configuration, choose UDP even when TCP is found.
4. Try calling a number and do the following
Note - 403 error or one-way audio error mainly occurs when network is changed from wireless to wired or to another wireless network( Range Extender) or due to double nat. My connection is stable when I am not switching between wired/wireless networks. Do the following to solve it every time you switch network or when you encounter some errors.
5. Try calling a number again.
Configuring GS Wave app on android. ( you can also configure Zoiper app too )
1. Adding an account. ( Settings - Account Settings - Click on + - Sip Account - fill the details)
2. Check, If the account is registered or not.
3. Add outbound proxy. (Settings - Account Settings - Tel no - Network Settings - Outbound proxy)
4. Connection mode - wifi. (Settings - Advance Settings - Network Settings - Network - Check wifi only)
5. Try calling a number.
6. If the abovesaid 403 error occurs, just deactivate-activate the account again.
Sorry for the long thread.
Have you tried disabling-enabling sip account in Zoiper 5?
Are you able to ping the SIP server if SIP is disabled.?
Change VLAN to 1831, and check the status and TEL no is up or not.
When calling through Zoiper the range bar is green or black?
Any error like 403 appears while calling?
yes tried disabling enabling.
When SIP is disabled:
able to ping SIP server, able to login to ZOIPER but outgoing 404 error, one green bar rest black. same as SIP enable.
On GS wave on mobile able to login but not able to make call.
When SIP enable: able to login to ZOIPER, receive calls. not able to make. 404 error. one green bar rest black. On GS wave mobile, able to make/get call.. in all cases NO Audio.
VLAN 1831: IPoE server goes down, VOIP no not registered, light on router for phone goes off.
Share the routing table again without blocking the network destination and subnet mask.
Connect your pc/laptop directly to ONT using LAN cable then Try to ping the sip server after changing network dest- 192.0.0.0 and subnet mask - 255.0.0.0. Then use Zoiper to check if it works or not. Also, use Open Resource Monitor ( Task manager - Performance ) while calling to check Zoiper's network activity.
Restart or enable-disable sip account in Zoiper whenever you make some changes in ONT's setting.
Have you tried configuring micro sip or yate?
Your SIP server 192.168.149.78 is really odd most of the sip servers that I have found are in this format - 10.187._.12 ( the blank part differs from circle to circle).
I think @maverick27 is also using Syrotech ONT. I hope he and @sloj help you as they are more familiar with this web interface.
Yes, I also tried all combinations of 10.187._.12 from 1 to 9 , but none of those was getting VOIP registered or get it ping by ONT using voice profile. only 192.168.149.78 is IP which I could ping from ONT using Voice profile. Yes tried microsp and Yate as well. same issue.
Yes Zoiper shows 0.1Mbps network while in the call. .here it is modified route table(even then same issues) as suggested by you
uploaded image post of bitrate audio recived/sent in zoiper app.. it is in moderation yet. received bitrate was zero. however, received bytes/payload was 227kb and more increasing as call duration
