Configuration for VOIP/SIP calls( using Zoiper/GS Wave) on Huawei ONT and TP Link Router.
  • Thread starter Thread starter AARON NASH
  • Replies Replies 97
  • Views Views 31,724
First, I want to thank @varkey for this ONT(HG8120C).
This configuration thread is mainly for Huawei ONT with TP-Link routers.
For configuring other ONT brands like DBC, Syrotech, Netlink and for more details you can view @sloj's thread -FTTH VOIP SIP Softphone configuration with ONT/ONU. (Now works on some more apps) | BSNL Bharat Fiber Broadband
Configuration for Ont and Router
For configuring you need to get the following details from Bsnl/LCO.
  • For Internet
  1. VLAN ID
  2. Username
  3. Password
  • For VOIP(static)
  1. VLAN ID
  2. IP Address
  3. Subnet Mask
  4. Default Gateway
  5. Primary DNS Server
  6. Secondary DNS Server
  • FOR SIP ACCOUNT
  1. Regist/Auth User Name- 91<stdcode><telphone number>
  2. Password- 0000 or last four digits of the telephone number
  3. Sip Server- 10.187.6.12 (kerala)
Log in to ONT's Web Interface
1.Create a wan profile for internet using the credentials provided by Bsnl. ( Wan - WAN Configuration - click on NEW)
2. Create another wan profile for VOIP-Internet.
3. Configure VoIP details. ( Voice - VoIP Basic Configuration)
4. Check the status of Wan profiles and VOIP. ( Status - WAN Information - VoIP Information)
5. Enable SIP. ( Network Application - ALG Configuration)
6. To ping the sip server, we have to create a Static Route. ( Route - Static Route Configuration - Click on new )
Note- 1. Gateway is the same Default Gateway asked in Voip wan profile.
2. Do not enable Default Route.
Go to Routing Table, to check the new Static route.
7. Ping Sip Server using Ping Test from Ont. ( System Tools - Maintenance)
8. Log in to your TP-link router ( archer c6) and enable Sip. ( Advanced - Nat Forwarding - ALG)
Note - Those who have D-Link routers might have to disable sip in order ping the sip server- Why won’t my VoIP device work with my router?
9. Ping Sip server from your PC/Laptop.
Configuring Zoiper 5 on PC/Laptop using Windows 10.
1. Add Username/login - 91<stdcode><telphone number>
Password - 0000 or last four digits of the telephone number
2. Add Sip server, port no and also add outbound proxy( same as sip server).
3. After testing configuration, choose UDP even when TCP is found.
4. Try calling a number and do the following
Note - 403 error or one-way audio error mainly occurs when network is changed from wireless to wired or to another wireless network( Range Extender) or due to double nat. My connection is stable when I am not switching between wired/wireless networks. Do the following to solve it every time you switch network or when you encounter some errors.
5. Try calling a number again.
Configuring GS Wave app on android. ( you can also configure Zoiper app too )
1. Adding an account. ( Settings - Account Settings - Click on + - Sip Account - fill the details)
2. Check, If the account is registered or not.
3. Add outbound proxy. (Settings - Account Settings - Tel no - Network Settings - Outbound proxy)
4. Connection mode - wifi. (Settings - Advance Settings - Network Settings - Network - Check wifi only)
5. Try calling a number.
6. If the abovesaid 403 error occurs, just deactivate-activate the account again.
Sorry for the long thread.
So, this far it was all based on assumptions that the SIP address is 192.x.x.x. LOL. Like I said previously, SIP enabled, "Turn off LAN DHCP" ticked for it to work on mobile apps.
So who provided the phone number, LCO? But then why was VOIP not configured?
LCO did not make voip confiuration as I didn't buy landline set. Yes I first started with 10.187.x.12 and then tried all combo didn't work. tried 192.168.149.78, it worked but one way audio persist..then got 10.187.1.143... one way audio persists, disabled SIP and (ticked "turned off lan dhcp") audio issue resolved but no incoming plus only working on yate.. trying SIP enable. but audio issue come back.... don't know if I able be to resolve this.
@pillaicha
Yes, I do have a landline phone connected to the tel port of ONT.
The incoming calls are forwarded to the newly registered SIP client or last used device. If your SIP client is deactivated or not registered(when wifi is off), then incoming calls are redirected to the landline.
Hey @AARON NASH could you setup SIP on your native Android SIP client with any of those TP-Link or Huawei routers?
If my router ever geta busted, I need to set my priorities.
I tried so badly to setup SIP calling on native Android on my Netlink HG323RGW router with the below version.
Hardware VersionV3.6
SoftWare Version2.0.08-200929
SIP works smoothly on Zoiper, linphone, GS wave lite app.
But native Android is obviously better.
P.S
In Xiaomi phones there's straight up SIP settings but in Samsung and Realme you need to download an app called Galaxy SIP. OnePlus too has one I believe.
If you own any of these please do try it and let me know.
Please help me.
I have Syrotech ONT with BSNL FTTH.
Steps done by me.
1. Created VOICE INTERNET profile DHCP using 1830vlan, so IoPE IP is UP and running. SIP mode enabled.
2.Done VOIP configuration also routing of sip. I can ping my sip from the command prompt in windows now. 0% loss.
3. Installed and able to login to in ZoIPER. able to receive call. BUT NO AUDIO at all. Configured android apps like GS wave, zoiper etc.. Able to make/recieve call.BUT NO AUDIO at all.
Hi i need your help regarding voip over zoiper or any other app with sip ip 192.168.149.78 (upe)
