Connection not lasting 5 minutes
i have straight away connected the line to modem .. since i least use the phone .. moreover i dont know where my splitter is ...
will post the screenshot soon...
this connection within this post have disconnected atleast 5 times...
guys i need ur help fast another disconnect .. damn !!!!
( off topic.. when i was on airtel.. the connection and service were awesome ... damn i should better pay my outstand ing and get my airtel back.. )
here is the screeny .. ( iwas about to post this reply and take the screenshot .. but within that time it has disconnected twice... )
i think this is the one ...
i get diff values...each time it disconnectes and reconnects...
i didnt find that page....
but i stumbled upon this page .....
dude can u add me to ur yahoo messenger > naveen_reloaded@yahoo.co.in
so that we can talk directly...
same settings shown in different manner. ( i said similar page Not Exact page)For a stable Connection GDMT and Bitswap enabled will do.If you loose connection add T413.Save and reboot.Check Statistics/Adsl page and see Line Speed has reduced SNR should improve.Always confirm /answer queries raised. You have not mentioned anything about phone/s in other rooms.I am using BSNL and Airtel for past two years without any problem.Sorry. I cannot give my email ID or phone number. You may be staying in next street , in same area to me even !!!!!!
ok ... where to add t413...i think if u see the screenshot ...did the setting marked were ok ???now for the past 15 mins the line is stable ... i did nt change any setting ... wht could be the reason ??/and wht will or could i possibly do with ur email id bro , no matter where u are .. i am not a hacker ... or anything that sort...anyway its ur wish not to give...wht should be the line speed ???wht could possibly disconnect the connection that frequently
Default in a modem all are selected.
In WAN page mod may be AUTO.
Depending on line conditions modem selects adsl gdmt etc.
You remove the "right" mark from the mod list.
Test your speed at Speedtest.net - The Global Broadband Speed Test say mumbai server now.
Repeat the tests after every change you make in the modem or computer.
Since you have NOT changed anything and the connection is stable , your problem is solved ! Make a note of present settings of the modem.
again disconnected...please bro can u tell me someother solution from seeing the screenshots i have posted...i dont know wht to do
What changes you made to modem settings ?You are on "always On Mode" meaning as soon as you start the system /modem you get connected to internet. That is why you could get your password.See in the WAN page above and select time IDLE time as 0and "always ON""Bridged" means you have to use a dialer program to connect, where you enter your user ID and PW to connect to Internet. ( Changes to be made in modem )If you change the mod settings some improvement possible.Else go to BSNL Telephone exchange and get the modem replaced .Confirm NOBODY is using a phone in your house.
does incoming calls have any effect ??coz now the connection is pretty stable...i dont know wht the hell is happeneing .. its stable for last 1 hr or so..
