dm111p :( need help
  • Thread starter Thread starter lsd
  • Views Views 1,500
lsd
bsnl
Everything was working fine until my modem burned, so i decided to get a new one and got Netgear dm111p modem. I finished installing the modem it also started working , but later it started to give problems. When connected there's a info regarding lease time(5mins). Every 2 minutes it tries to renew the ip and get a new lease. Most of time it would just lag while i am browsing or playing counter strike. I also tried various other settings. I tried the RFC briding, it disable the dhcp server and modem does'nt requests for new ip and lease but there's also the same problem. Before netgear everything worked fine , dont have any idea wat's going on . Here's my configurating Windows IP Configuration Host Name . . . . . . . . . . . . : computer Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : homeEthernet adapter Local Area Connection: Connection-specific DNS Suffix . : home Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethernet NIC Physical Address. . . . . . . . . : 00-0F-B0-9F-CA-19 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 59.94.178.217 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 59.94.178.218 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 218.248.240.79 Lease Obtained. . . . . . . . . . : Tuesday, August 07, 2007 9:09:33 PM Lease Expires . . . . . . . . . . : Tuesday, August 07, 2007 9:14:33 PMi need help plzz :confused:
