Fast Auto Login Script for Reliance Broadband
  • Thread starter Thread starter pteek
  • Replies Replies 57
  • Views Views 51,347
Status
Not open for further replies.
Would it be fine if I keep the downloaded file in a created folder on my C Drive? Doing it now, will report back. Thanks :)
Any folder. Python would most likely install itself into the PATH configuration allowing you to run .py files from anywhere on the machine. You can put it on desktop and double click on it to dial in. You can put it in startup folder. Even taskbar. Anywhere. I have it scheduled to run at boot time using Task Scheduler in Windows.
I am using a different one right now coded by a friend rather than this as he said this script basically DDoS Google Public DNS IPs or something like that.
It is fairly simple really. You need to install Python on your computer...
Download Python | Python.org
After that you download the script and put it in a folder.
You edit the file with your username and password.
And then you run the file. Double Clicking might work. I run it through command line like this:
e:\Vedant\keepalive.py
I am afraid your friend is confused here. 1 TCP handshake every 10 seconds from 1000s of users(absolute max for this script) won't even come close to DDOSing Google public DNS which handles >80,000 request per second worldwide.
I choose Google because Reliance peers with them and they are among the companies that handle largest amount of traffic on the Internet.
well of course, google can handle any kind of traffic you can send to their servers and pings are nothing compared to what they deal with every second. the point my friend was trying to make was that there was no need to continuously ping google dns to verify if the connectivity had broken or not.
now i do not know what technique he is using to verify if the connection is working or not. you can check his version of the script here:
I did like your version of the script because it did work great in the background. Though you have made some changes in the recent times? I recently checked it and there was need for another package in addition to Python?
I could not get the script above to run continuously in the background. But it does work fine to login to Reliance gateway when their freaking login page does not load. It also crashes randomly so running it in foreground also has not worked for me.
Status
