Get 2mbps Download Speed on MTNL Broadband Freedom 800 Plan
  • Thread starter Thread starter onlytest
  • Replies Replies 1,305
  • Views Views 140,642
anant.del said:
getting reset every one min now :
Does your modem show CRC errors? Does your phone have noise? I was having the same problem since 1-2 days, complained to MTNL. The linesman came and told me he had cleaned the line (and that there were 'carbon deposits' on it. Its working perfectly now.
na it only happens during morning time when my dam script doesn't work properly and misses the reset time and i have to do it manually !
the reset adapter that u got bro, it will fit directly in with my 2 pin modem plug na ? i might get one too. its connecting and disconnecting on its own ? :)
Manu said:
why would a reset before 7:43 affect your speed, did you reset at 7:43?
It auto reset & speed dropped to 512 at 730 am, then kept disconnecting every 4-5 minutes , same problem as anant.del , now after another auto reset its back to 512
ok cool tx! where can i check for these crc errors btw on the beetel modem page ?
line sounds clear though :)
Not a modem problem i am also having the same issue today
