Hathway Broadband launches Docsis 3.0 Ultra High speed network
  • Thread starter Thread starter gopichandpai
  • Replies Replies 312
  • Views Views 105,681
shethsa said:
So far so good. You will not get 50 Mbps download speeds if you use wifi router. Probably upto 35
Did you buy a new router(which one?) yourself or are you using the router(which one?) they provided?
Which plan are you on? And did you incur any extra charges like extra taxes, installation, etc?
shethsa said:
Nope. Their D-Link router. I'm on 10gb @787 bucks right now all inclusive but will probably shift to a higher plan. Installation is 1k plus tax. That's it.
Ok. Thanks mate.
AmitT said:
@shethsa, I have been getting 45 to 48 Mbps on my wifi as well provided I am in direct line of sight of the wifi router. I use the Dlink N Powerline router DHP-1320 (see http://www.dlink.com/us/en/home-solutions/connect/powerline/dhp-1320-wireless-n-powerline-router) and I am getting the speeds. I need powerline as I use my power wiring to create a lan within my house. Been using it for the past 3-4 years. Works like a charm.
Where did you buy the powerline router from? None of the online retailers seem to be selling any.
