totally feel disappointed ,yes
Asus ax53u has weak dual core ,with sqm at 55000 kbps ,one core indeed reach 80% of one core ( most probably it sqm use one core)
ax53u has 2 core 2 threads ,but sqm use only cpu and sqm does add some latency ( browsing with cake sqm will always something wrong happening ,no matter what , because it hold packets for very short amonut of time )
my conclusion is that
router is not enough for running openwrt , now later this year ,when i buy mini pc ,i will use
pi 5 ( it has much stronger cpu ,can handle sqm with cake even for 500 mbps )
and why i feel asuswrt is smooth ,it does use hardware offload ,it means ,with asuswrt ,most things worked handle by hardware
and when i installed openwrt , i already loosed half power of my router
asuswrt is optimised for balancing load between cpu and hardware offload ,thats why i feel asuswrt is smooth ( not much difference )
im in super deep confusion ,what to do now ?
i wants to use pi 5 ,but im heavily depend on it ,as it handles immich ,jellyfin ,qbittorrent and autobrr ( automation of downloading movies and webseries ) and
VPN
looks like i should move back to asuswrt for some months and on dilwali when i buy mini pc ,i will use pi 5 for openwrt
i should have researched more on this
currently pi 5 1gb and nanopi r3s cost same ( around 4800 rs ) ,if i knew about this already ,then i would have purchased a average dual band router and nanopi r3s
now i strongly needs your suggestion , at 55000 sqm does handles good ,but some kind of laggyness in browsing
what should i do now ,should i remain with openwrt or move back to asuswrt
