[help] Spectra Ping / Traceroute results to Singapore
Ah that way, but it was never unblocked even if we were using DNS-over-HTTPS or DNS-over-TLS right. They appeared to have been using the SNI info to block sites.
Anyway yeah, many such sites over HTTPS aren't blocked anymore.
nope they don't seem to be doing that anymore like before you can just get into any blocked site by just using https
Correct, I was just stating that they were doing SNI based blocking earlier and DNS over TLS nor DNS over HTTPS didn't help either.
Now it works if you just use HTTPS. (y)
Routing on spectra has improved a bit but only to the IP's that we were able to provide but for the rest of the internet its still very bad (there might be one or two subnets in my locality where routing to asian countries is absolutely great )
here is a traceroute for a IP i got them to fix
Code:
tracert speedtest.singapore.linode.com
Tracing route to speedtest.singapore.linode.com [139.162.23.4]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  www.routerlogin.com [192.168.1.1]
  2     1 ms     1 ms     1 ms  10.201.137.1
  3     1 ms     1 ms     1 ms  203.92.63.177.reverse.spectranet.in [203.92.63.177]
  4    10 ms     9 ms     9 ms  203.92.63.134.reverse.spectranet.in [203.92.63.134]
  5    11 ms    11 ms    11 ms  182.19.62.202
  6    45 ms    46 ms    46 ms  ae4-100-xcr1.sng.cw.net [212.165.2.1]
  7    46 ms    45 ms    45 ms  linode-gw.sng.cw.net [195.2.19.230]
  8    46 ms    46 ms    46 ms  139.162.0.10
  9    46 ms    46 ms    46 ms  speedtest.singapore.linode.com [139.162.23.4]
Trace complete.
and here is the routing for PIA singapore VPN server
Code:
tracert sg.privateinternetaccess.com
Tracing route to sg.privateinternetaccess.com [37.120.208.80]
  3     2 ms     2 ms     1 ms  203.92.63.177.reverse.spectranet.in [203.92.63.177]
  4     1 ms     1 ms     1 ms  203.92.63.181.reverse.spectranet.in [203.92.63.181]
  5    15 ms    15 ms    16 ms  203.92.63.146.reverse.spectranet.in [203.92.63.146]
  6    52 ms    51 ms    50 ms  182.19.88.106
  7    45 ms    44 ms    44 ms  182.19.106.111
  8   140 ms   141 ms   141 ms  if-ae-18-0.tcore1.wyn-marseille.as6453.net [80.231.217.185]
  9   157 ms   157 ms   157 ms  if-ae-5-6.tcore1.mlv-mumbai.as6453.net [180.87.38.125]
 10   155 ms   153 ms   153 ms  if-ae-2-2.tcore2.mlv-mumbai.as6453.net [180.87.38.2]
 11   157 ms   157 ms   156 ms  if-ae-16-2.tcore1.svw-singapore.as6453.net [180.87.12.226]
 12   156 ms   156 ms   156 ms  if-ae-11-2.thar1.svq-singapore.as6453.net [180.87.98.37]
 13   161 ms   159 ms   159 ms  180.87.98.118
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16   159 ms   159 ms   159 ms  37.120.208.80
Trace complete.
PIA SG is an absolute mess on my isp as well
traceroute to sg.privateinternetaccess.com (37.120.208.83), 30 hops max, 60 byte packets
1 _gateway (192.168.5.1) 0.381 ms 0.349 ms 0.330 ms
2 10.89.139.1 (10.89.139.1) 1.498 ms 1.493 ms 1.520 ms
3 103.248.93.1 (103.248.93.1) 3.680 ms 3.673 ms 3.594 ms
4 nsg-static-209.68.75.182-airtel.com (182.75.68.209) 5.094 ms 5.115 ms 4.873 ms
5 182.79.154.18 (182.79.154.18) 158.615 ms 182.79.134.229 (182.79.134.229) 163.458 ms 182.79.154.16 (182.79.154.16) 163.321 ms
6 ldn-b4-link.telia.net (62.115.162.232) 161.863 ms 162.616 ms 159.762 ms
7 ldn-bb4-link.telia.net (62.115.134.138) 316.741 ms ldn-bb3-link.telia.net (62.115.134.134) 317.665 ms 312.593 ms
8 prs-bb4-link.telia.net (62.115.114.229) 288.318 ms 292.080 ms prs-bb3-link.telia.net (62.115.134.92) 338.938 ms
9 mei-b2-link.telia.net (62.115.133.177) 146.996 ms mei-b2-link.telia.net (62.115.133.175) 150.260 ms mei-b1-link.telia.net (62.115.124.215) 151.540 ms
10 mei-b2-link.telia.net (62.115.116.13) 152.320 ms snge-b1-link.telia.net (62.115.141.147) 287.504 ms mei-b1-link.telia.net (62.115.116.27) 151.366 ms
11 snge-b1-link.telia.net (62.115.141.147) 285.237 ms m247-ic-325156-snge-b1.c.telia.net (62.115.155.103) 312.256 ms 312.482 ms
12 37.120.220.219 (37.120.220.219) 308.082 ms m247-ic-325156-snge-b1.c.telia.net (62.115.155.103) 325.750 ms 37.120.220.219 (37.120.220.219) 345.395 ms
13 37.120.220.87 (37.120.220.87) 293.509 ms 290.955 ms hnk-b2-link.telia.net (62.115.116.8) 307.282 ms
14 * 37.120.220.87 (37.120.220.87) 293.709 ms 37.120.208.83 (37.120.208.83) 314.132 ms
traceroute to speedtest.singapore.linode.com (139.162.23.4), 30 hops max, 60 byte packets
1 _gateway (192.168.5.1) 0.141 ms 0.210 ms 0.279 ms
2 10.89.139.1 (10.89.139.1) 1.539 ms 1.543 ms 1.543 ms
3 103.248.93.1 (103.248.93.1) 1.779 ms 1.766 ms 1.746 ms
4 nsg-static-209.68.75.182-airtel.com (182.75.68.209) 3.096 ms 3.818 ms 3.799 ms
5 182.79.224.145 (182.79.224.145) 69.182 ms 182.79.152.162 (182.79.152.162) 75.666 ms 182.79.224.183 (182.79.224.183) 79.206 ms
6 63949.sgw.equinix.com (27.111.228.235) 70.385 ms 72.089 ms 68.594 ms
7 139.162.0.14 (139.162.0.14) 71.438 ms 139.162.0.6 (139.162.0.6) 68.990 ms 139.162.0.14 (139.162.0.14) 77.356 ms
8 * speedtest.singapore.linode.com (139.162.23.4) 72.235 ms 72.197 ms
