[help] Spectra Ping / Traceroute results to Singapore
Interesting, I've never got an IP outside of the 180.151.x.x series. Or you mean the pings to that IP address? It's a Singapore IP address - 216.185.103.X
Ah okay i didn't notice i had a proxy running in Chrome! 😂 I think it was 180.151.224.x the IP that was assigned to
Again down :( Got the below message at 12:04 PM, but net is down since 10:22 AM.
Hmm weird i didn't notice any downtime the home server checks every 15 minutes for downtime too but didn't notice any
Also i got your ticket has been resolved message around 10AM itself
@varkey ip refreshed assigned to new subnet 180.151.203.x bad latency so tried to change ip multiple times
180.151.225.0
180.151.108.0
180.151.119.0
180.151.125.0
but everything is the same tried to reverse trace on other subnets where we got good pings but even those have very high latency at the spectras end 203.92.63.133.reverse.spectranet.in
i think Spectra screwed something up again
Code:
[root@varkey-minipc ~]# ping speedtest-sgp1.digitalocean.com
PING speedtest-sgp1.digitalocean.com (159.89.192.182) 56(84) bytes of data.
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=1 ttl=52 time=284 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=2 ttl=52 time=283 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=3 ttl=52 time=283 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=4 ttl=52 time=283 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=5 ttl=52 time=283 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=6 ttl=52 time=283 ms
^C
--- speedtest-sgp1.digitalocean.com ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5000ms
rtt min/avg/max/mdev = 283.090/283.535/284.223/0.578 ms
Code:
[root@varkey-minipc ~]# mtr -w speedtest-sgp1.digitalocean.com
Start: Tue May  7 13:24:37 2019
HOST: varkey-minipc                                Loss%   Snt   Last   Avg  Best  Wrst StDev
  1.|-- router.lan                                    0.0%    10    0.5   0.4   0.3   0.5   0.0
  2.|-- 10.201.116.1                                  0.0%    10    1.1   0.9   0.8   1.1   0.0
  3.|-- 203.92.63.177.reverse.spectranet.in           0.0%    10    1.0   1.1   0.9   1.3   0.0
  4.|-- 203.92.63.181.reverse.spectranet.in           0.0%    10    1.3   1.7   0.9   6.4   1.5
  5.|-- 203.92.63.146.reverse.spectranet.in           0.0%    10   23.9  23.8  23.5  24.3   0.0
  6.|-- ix-ge-11-3-7-0.tcore1.pye-paris.as6453.net    0.0%    10  125.3 124.5 124.0 125.3   0.0
  7.|-- if-ae-8-1600.tcore1.wyn-marseille.as6453.net  0.0%    10  282.8 284.7 282.5 300.1   5.4
  8.|-- if-ae-5-2.tcore1.mlv-mumbai.as6453.net        0.0%    10  290.8 287.9 287.2 290.8   1.0
  9.|-- if-ae-2-2.tcore2.mlv-mumbai.as6453.net        0.0%    10  288.6 287.8 287.3 288.6   0.0
 10.|-- if-ae-26-2.tcore1.svw-singapore.as6453.net    0.0%    10  284.6 283.8 283.1 284.8   0.3
 11.|-- if-ae-11-2.thar1.svq-singapore.as6453.net     0.0%    10  280.7 280.7 280.4 281.0   0.0
 12.|-- 120.29.214.50                                 0.0%    10  282.8 283.1 282.7 284.0   0.0
 13.|-- ???                                          100.0    10    0.0   0.0   0.0   0.0   0.0
 14.|-- ???                                          100.0    10    0.0   0.0   0.0   0.0   0.0
 15.|-- 159.89.192.182                                0.0%    10  283.6 284.0 283.3 286.6   1.0
[root@varkey-minipc ~]# curl icanhazip.com
180.151.116.x
Ah yeah okay just noticed they fixed the reverse route but screwed up the path it takes from bangalore to singapore
now its exactly opposite to previous situation
Could be a momentary issue i did go to raise a complaint but by the time they registered the complaint i tried reverse tracing couple of IP's and it seemed to be back at around 60-70 ms
right now assigned to
180.151.118.0 subnet
PS: Their Phone support is horrible never gonna try that again
Damn right. I usually log requests through chat or email.
The least ping I've seen for a reverse traceroute is 102ms. That was on a 117 subnet yesterday.
