[help] Spectra Ping / Traceroute results to Singapore
reverse trace to 180.151.203.x
Code:
                             My traceroute  [v0.86]
localhost (0.0.0.0)                                    Mon Apr 29 20:27:51 2019
Resolver: Received error response 2. (server failure)er of fields   quit
                                       Packets               Pings
 Host                                Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. 103.3.60.3                        0.0%     7   11.6   5.1   0.7  14.4   5.6
 2. 139.162.0.13                      0.0%     7   11.9   8.2   0.7  13.8   5.0
 3. ix-ae-19-0.tcore1.svw-singapore.  0.0%     7    3.8   8.7   1.5  13.6   4.7
 4. if-ae-2-2.tcore2.svw-singapore.a  0.0%     7    3.0   5.4   1.9  16.2   4.9
 5. 180.87.15.202                     0.0%     7   74.6  74.0  71.2  77.1   1.7
 6. 172.23.78.226                     0.0%     7   67.6  74.7  67.6  91.2   8.4
 7. 115.113.165.50.static-mumbai.vsn  0.0%     6   78.4  77.3  74.1  80.2   2.9
 8. 203.92.38.49.reverse.spectranet.  0.0%     6   76.5  76.9  74.3  82.9   3.4
 9. 203.92.63.62.reverse.spectranet.  0.0%     6   71.6  71.8  66.2  79.6   5.1
10. 203.92.63.182.reverse.spectranet  0.0%     6   69.7  75.5  66.9  86.0   7.7
11. ???
12. 180.151.203.x.reverse.spectran  0.0%     6   80.6  70.9  66.9  80.6   4.9
reverse trace to 180.151.117.0
Code:
localhost (0.0.0.0)                                    Mon Apr 29 20:29:52 2019
                                       Packets               Pings
 1. 103.3.60.3                        0.0%     5    3.5   4.7   1.2   8.9   2.9
 2. 139.162.0.13                      0.0%     5    7.1   7.1   2.1  11.5   3.8
 3. ix-ae-19-0.tcore1.svw-singapore.  0.0%     5    2.2  12.0   2.2  36.3  14.0
 4. if-ae-2-2.tcore2.svw-singapore.a  0.0%     5    4.8   4.4   0.9   7.8   3.4
 5. 180.87.15.202                     0.0%     5   79.4  70.7  66.7  79.4   5.2
 6. 172.23.78.226                     0.0%     5   68.1  70.4  66.9  76.1   3.5
 7. 115.113.165.50.static-mumbai.vsn  0.0%     5   72.5  73.8  70.6  80.1   3.6
 8. 203.92.38.49.reverse.spectranet.  0.0%     5   73.6  75.5  72.6  78.4   2.3
 9. 203.92.63.145.reverse.spectranet  0.0%     5   62.3  66.9  62.3  76.2   5.4
10. 203.92.63.182.reverse.spectranet  0.0%     5   64.6  65.7  61.5  71.0   4.5
11. ???
Yup seems to be fixed atleast the reverse route. I think the traceroute was fine so this should all around fix this.
Also this goes through mumbai unlike 224 subnet which had 42 ms ping so this will add about 20-40 ms more latency but still so much better now its very much usable
reverse trace to 180.151.116.0 still the same
Code:
localhost (0.0.0.0)                                    Mon Apr 29 20:35:49 2019
                                       Packets               Pings
 1. 103.3.60.3                        0.0%     3    1.6   3.3   1.6   6.3   2.4
 2. 139.162.0.13                      0.0%     3   24.9  11.2   2.3  24.9  12.0
 3. ix-ae-19-0.tcore1.svw-singapore.  0.0%     3    6.8   9.1   1.9  18.5   8.5
 4. if-ae-31-7.tcore1.wyn-marseille.  0.0%     3  149.5 150.0 149.5 150.5   0.0
 5. if-ae-8-1600.tcore1.pye-paris.as  0.0%     3  173.4 171.2 164.3 175.9   6.0
 6. 80.231.154.118                    0.0%     3  170.7 164.0 159.0 170.7   6.0
 7. 203.92.63.145.reverse.spectranet  0.0%     3  157.2 156.3 155.3 157.2   0.7
 8. 203.92.63.182.reverse.spectranet  0.0%     3  160.5 162.2 158.2 167.9   5.0
 9. ???
251 subnet
PING 180.151.251.x (180.151.251.x) 56(84) bytes of data.
64 bytes from 180.151.251.x: icmp_seq=1 ttl=55 time=194 ms
64 bytes from 180.151.251.x: icmp_seq=2 ttl=55 time=194 ms
64 bytes from 180.151.251.x: icmp_seq=3 ttl=55 time=193 ms
64 bytes from 180.151.251.x: icmp_seq=4 ttl=55 time=193 ms
--- 180.151.251.x ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3194ms
rtt min/avg/max/mdev = 193.320/193.921/194.829/0.627 ms
traceroute to 180.151.251.x (180.151.251.x), 30 hops max, 60 byte packets
1 ge2-8.r01.sin01.ne.com.sg (202.150.221.169) 0.147 ms 0.161 ms 0.174 ms
2 10.15.62.214 (10.15.62.214) 0.198 ms 0.210 ms 0.215 ms
3 s4-6-r10.cyberway.com.sg (203.117.6.209) 1.940 ms 2.016 ms 2.088 ms
4 203.118.15.81 (203.118.15.81) 1.719 ms 1.832 ms ancoretl02-anatlint11.starhub.net.sg (203.118.15.85) 1.594 ms
5 anutli13.starhub.net.sg (203.118.12.46) 20.932 ms 21.237 ms 1.682 ms
6 ix-ae-25-101.tcore1.svw-singapore.as6453.net (180.87.12.161) 1.652 ms 1.617 ms 1.610 ms
7 if-ae-31-7.tcore1.wyn-marseille.as6453.net (80.231.217.94) 174.427 ms if-ae-31-6.tcore1.wyn-marseille.as6453.net (80.231.217.90) 155.902 ms if-ae-31-7.tcore1.wyn-marseille.as6453.net (80.231.217.94) 174.511 ms
8 if-ae-8-1600.tcore1.pye-paris.as6453.net (80.231.217.6) 173.698 ms 176.235 ms 176.139 ms
9 80.231.154.118 (80.231.154.118) 368.720 ms 368.560 ms 368.447 ms
10 203.92.63.62.reverse.spectranet.in (203.92.63.62) 393.374 ms 393.291 ms 393.210 ms
11 203.92.63.182.reverse.spectranet.in (203.92.63.182) 199.007 ms 193.652 ms 198.941 ms
12 * * *
117 just to confirm the Mumbai routing
PING 180.151.117.x (180.151.117.x) 56(84) bytes of data.
64 bytes from 180.151.117.x: icmp_seq=1 ttl=54 time=105 ms
64 bytes from 180.151.117.x: icmp_seq=2 ttl=54 time=103 ms
64 bytes from 180.151.117.x: icmp_seq=3 ttl=54 time=103 ms
64 bytes from 180.151.117.x: icmp_seq=4 ttl=54 time=103 ms
--- 180.151.117.x ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3107ms
rtt min/avg/max/mdev = 103.840/104.206/105.136/0.538 ms
traceroute to 180.151.117.x (180.151.117.x), 30 hops max, 60 byte packets
1 ge2-8.r01.sin01.ne.com.sg (202.150.221.169) 0.168 ms 0.177 ms 0.186 ms
2 10.15.62.214 (10.15.62.214) 0.200 ms 0.209 ms 0.220 ms
3 s4-6-r10.cyberway.com.sg (203.117.6.209) 2.167 ms 2.203 ms 2.284 ms
4 ancoretl02-anatlint11.starhub.net.sg (203.118.15.85) 1.455 ms 203.118.15.81 (203.118.15.81) 1.484 ms 1.674 ms
5 anutli13.starhub.net.sg (203.118.12.46) 1.459 ms 1.647 ms 1.534 ms
6 ix-ae-25-101.tcore1.svw-singapore.as6453.net (180.87.12.161) 1.622 ms 1.427 ms 1.446 ms
7 if-ae-2-2.tcore2.svw-singapore.as6453.net (180.87.12.2) 36.932 ms 36.837 ms 36.786 ms
8 180.87.15.202 (180.87.15.202) 64.527 ms 64.541 ms 64.549 ms
9 * * *
10 115.113.165.50.static-mumbai.vsnl.net.in (115.113.165.50) 65.801 ms 68.545 ms 65.813 ms
11 203.92.38.49.reverse.spectranet.in (203.92.38.49) 261.150 ms 261.271 ms 261.004 ms
12 203.92.63.145.reverse.spectranet.in (203.92.63.145) 300.037 ms 203.92.63.62.reverse.spectranet.in (203.92.63.62) 300.726 ms 300.740 ms
13 203.92.63.182.reverse.spectranet.in (203.92.63.182) 107.714 ms 108.176 ms 107.968 ms
14 * * *
Thanks guys, I have sent them an email regarding 116 and 251. I'm working with a person named Sumit Kumar who appears to be from Spectra L2 team (from the ccd email address)
@The_PC_Guy 120 doesn't even seem to go past Paris, did you ever get an IP address from that subnet?
Okay got assigned to 180.151.120.x subnet cant even ping from this IP this explains why you were only able to see upto paris. Ping for some reason is blocked on this IP there was one more IP that did this dont remember which one it was
@The_PC_Guy Mine's also down from 12:30 AM or so.
Got an SMS
"Hi! You might be experiencing some service disruption. Our team is working on resolution. ETR is 0430 hours. Team Spectra.
Got another message sometime back saying now the ETA is 10 AM
Hi! We are experiencing some ground challenges which is delaying outage restoration. Revised ETR is 1000 hrs. Thanks for your co-operation. Team Spectra.
