[help] Spectra Ping / Traceroute results to Singapore
Interesting, even my pings are sub 50ms. Nice! I'm on 180.151.124.0/24 subnet
Code:
[root@varkey-minipc ~]# ping -c 4 speedtest-sgp1.digitalocean.com
PING speedtest-sgp1.digitalocean.com (159.89.192.182) 56(84) bytes of data.
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=1 ttl=51 time=42.9 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=2 ttl=51 time=41.9 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=3 ttl=51 time=42.3 ms
64 bytes from 159.89.192.182 (159.89.192.182): icmp_seq=4 ttl=51 time=41.9 ms
--- speedtest-sgp1.digitalocean.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 41.961/42.304/42.925/0.415 ms
[root@varkey-minipc ~]# ping -c 4 speedtest.singapore.linode.com
PING speedtest.singapore.linode.com (139.162.23.4) 56(84) bytes of data.
64 bytes from speedtest.singapore.linode.com (139.162.23.4): icmp_seq=1 ttl=51 time=45.0 ms
64 bytes from speedtest.singapore.linode.com (139.162.23.4): icmp_seq=2 ttl=51 time=47.8 ms
64 bytes from speedtest.singapore.linode.com (139.162.23.4): icmp_seq=3 ttl=51 time=43.4 ms
64 bytes from speedtest.singapore.linode.com (139.162.23.4): icmp_seq=4 ttl=51 time=43.6 ms
--- speedtest.singapore.linode.com ping statistics ---
rtt min/avg/max/mdev = 43.450/45.011/47.855/1.766 ms
@404 are you in bangalore and area? also if possible raise a complaint with spectra if many people report it they might just give in and fix it
@The_PC_Guy @varkey I'm in BLR and in 180.151.117.x subnet. I have complained about their routing with a few streaming services not running properly as examples. I don't have the means or the know-how to give exact network data to their engineers. They did some tests remotely and just gave up.
Using this page to run traceroutes from SG to my IP.
Results
Spectra:
traceroute to 180.151.117.x (180.151.117.x), 30 hops max, 60 byte packets
1 ge2-8.r01.sin01.ne.com.sg (202.150.221.169) 0.161 ms 0.179 ms 0.209 ms
2 203.208.177.109 (203.208.177.109) 0.473 ms 0.441 ms 0.496 ms
3 203.208.173.22 (203.208.173.22) 178.186 ms 203.208.154.46 (203.208.154.46) 176.810 ms 203.208.151.182 (203.208.151.182) 165.085 ms
4 203.208.171.117 (203.208.171.117) 165.119 ms 160.463 ms 165.092 ms
5 203.208.183.38 (203.208.183.38) 190.152 ms 188.961 ms 185.572 ms
6 if-ae-2-2.tcore2.lvw-los-angeles.as6453.net (66.110.59.2) 249.797 ms if-ae-8-2.tcore1.sv1-santa-clara.as6453.net (66.110.59.9) 241.810 ms 241.808 ms
7 if-ae-0-2.tcore2.sv1-santa-clara.as6453.net (63.243.251.2) 248.864 ms 241.983 ms 249.338 ms
8 if-ae-18-2.tcore1.sqn-san-jose.as6453.net (63.243.205.72) 266.065 ms 257.994 ms if-ae-38-2.tcore1.sqn-san-jose.as6453.net (63.243.205.74) 263.139 ms
9 if-ae-1-3.tcore3.njy-newark.as6453.net (216.6.57.5) 248.018 ms 243.789 ms 243.905 ms
10 if-ae-7-2.tcore1.n0v-new-york.as6453.net (63.243.128.26) 255.651 ms 263.392 ms 262.757 ms
11 if-ae-3-2.tcore1.pye-paris.as6453.net (80.231.154.142) 247.278 ms if-ae-2-2.tcore2.n0v-new-york.as6453.net (216.6.90.22) 250.279 ms 246.401 ms
12 80.231.154.118 (80.231.154.118) 460.348 ms 458.145 ms if-ae-4-2.tcore2.l78-london.as6453.net (80.231.131.157) 262.074 ms
13 if-ae-2-2.tcore1.l78-london.as6453.net (80.231.131.2) 249.145 ms 249.996 ms 251.729 ms
14 203.92.63.182.reverse.spectranet.in (203.92.63.182) 280.952 ms if-ae-3-2.tcore1.pye-paris.as6453.net (80.231.154.142) 249.434 ms 203.92.63.182.reverse.spectranet.in (203.92.63.182) 278.112 ms
15 80.231.154.118 (80.231.154.118) 459.025 ms 461.616 ms 458.485 ms
16 203.92.63.62.reverse.spectranet.in (203.92.63.62) 474.411 ms 482.211 ms 468.492 ms
17 * * *
ACT:
traceroute to 103.227.97.x (103.227.97.x), 30 hops max, 60 byte packets
1 ge2-8.r01.sin01.ne.com.sg (202.150.221.169) 0.146 ms 0.156 ms 0.167 ms
2 s4-6-r10.cyberway.com.sg (203.117.6.209) 1.767 ms 1.906 ms 1.913 ms
3 203.118.15.81 (203.118.15.81) 1.454 ms 1.555 ms ancoretl02-anatlint11.starhub.net.sg (203.118.15.85) 1.535 ms
4 anutli13.starhub.net.sg (203.118.12.42) 1.425 ms 1.811 ms anutli13.starhub.net.sg (203.118.12.46) 1.713 ms
5 ix-ae-25-101.tcore1.svw-singapore.as6453.net (180.87.12.161) 1.574 ms 1.504 ms 1.484 ms
6 if-ae-2-2.tcore2.svw-singapore.as6453.net (180.87.12.2) 36.854 ms 36.553 ms 36.901 ms
7 180.87.15.6 (180.87.15.6) 62.720 ms 33.112 ms 33.179 ms
8 * * *
9 14.141.145.6.static-Bangalore.vsnl.net.in (14.141.145.6) 43.301 ms 42.345 ms 42.067 ms
10 broadband.actcorp.in (202.83.20.182) 42.307 ms 42.042 ms 40.416 ms
11 * * *
Is Spectra sending packets for a world tour? I'm not sure if I'm reading it right..
I've been on the 180.151.124.x subnet though the IP's are changing but on the same subnet and i hope the DHCP server always keeps me on this since 42ms ping for singapore is fantastic
yeah it is but the thing is few route through hong kong too!
For a service I want to use, I've seen it routes through HK. But this is just disappointing. This and their slow CC response times means I'll probably not continue from next month. Considering Airtel VDSL (Ugh, I know but it works flawlessly for the service I want) and pray for FTTH.
at least for now i'll stick to spectra and VPN or even take a secondary connection for latency sensitive applications until other ISP's start gigabit no FUP plans
