HG323RGW problem on BSNL Bharat Fiber Broadband
BSNL
HG323RGW is not connected to internet. And the status shows down in status of wan. Checked the user id and password. After replaced ONU it works fine. But this replaced ONU is works fine at other OLT's.
ISP - BSNL FTTH
Mr. Varkey ji please guide.
First of all Thanks for your reply.
1. Registered with olt. pon is good.
2. Yes its failing to make PPPoE connection.
3. Voice status shows up.
4. Works in bridge mode.
Is it compulsory to register ont with olt? I have purchased TP-Link Archer XR500v GPON. At first its aking gpon password, When I configure user name and password correctly, pon light blinks continuously, no loss of signal.
So should i ask bsnl to register my ont with olt and also ask Gpon password?
@srinivas39326 Yes, it is mandatory to register your ONU with the OLT if LCO has enforced authentication on the OLT, else it won't work.
Mostly serialnumber would be used for authentication, try setting the old ONU serial number on the TP-Link, if it didn't work, contact your LCO.
Sir thank you for your quick reply.
1)Sir if I keep old ont serial in new ont, then what password should I enter, Because its asking password?
2)Should I ask lco for GPON password after serial number entry?
3)Is it a difficult process to enter new serial number in olt, because lco is not giving proper response?
Please help me
Thanks in advance.
Sir this is the screen shot.
GPON password field can be empty, the ONU maybe appending some string to the entered serial number. Only your LCO can help whitelist the serial number in this case.
Netlink onu
User id password and vlan have no problem. Suppose change the onu it's work fine.
The onu which is problematic is running smoothly on other olt.
We have more than 15 to 20 onu's having randomly the same problem (netlink only). Other brands have no problem. This is a big headache.
Sir is this the netlink ont model you are using?
