HG323RGW problem on BSNL Bharat Fiber Broadband
BSNL
HG323RGW is not connected to internet. And the status shows down in status of wan. Checked the user id and password. After replaced ONU it works fine. But this replaced ONU is works fine at other OLT's.
ISP - BSNL FTTH
Mr. Varkey ji please guide.
Syrotech GPON 8 port OLT
1.Two days before ONT shut down due to power failure
2.After power ON some ont's PON didn't hold
3.when restart the OLT the problem solved
4.But again some new customers PON didn't hold
5. OLT Power OFF and ON
All ont have latest Firmware
but every time restart new set of customer got PON holding Problem
6. No problem in ONT or line or splitter ( if any problem means it will not connect after restart)
7. The problem ont will work in another location
8. After register with OLT PON holding but internet not connected
7. JTO from bsnl office says that REUPLOAD the firmware but Firmware update process will be failed in OLT
Any solution
why you flashed dbc firmware bro.. they all are vsol oem but every brands has its own firmware customized for it..
hard reset the ont n the nflash this attached official fw for nelink vsol oem
From where did you getting these files please give the link
First notedown the vlan of customer.
Then check whether there are two vlan entries for a ont. for example vlan is 200 there is two mac id's for same vlan which is one from uplink and another is ont mac.
If single mac is present
On OLT configuration >>>MAC >>> select which pon is problem..... then click clean and refresh.... and find for two mac for the vlan
Ok sir, I try it and what is the solution for PON holding Problem, If i add the ONT freshly it will hold but once ONT reboot or Power OFF then it will start blinking
i have it bro.. many of my clients uses chinese oem olt ont so i get these firmware from all those guys in Syrotech opti dbc fibrsl ntlnk.. tell me if u want.. bt beware of these chiense shit onts.. richerlink had also launched year ago in india they are cdata rebranded n they started to make custom fw for their onts.. if u buy bulk quantity u can tell me to give specific carrier lock fw which wil make that ont shit for other isp if u change
