@MZRecords Local technicians aren't knowledgeable with bridge mode and such. You can contact airtel customer care and raise a complaint asking them to remove bridge mode because your router is faulty. That way they will do it for sure. No need to ask any local person. They usually do it on the same day.
@Sanemi my xpon is in default setting only with default gateway of 192.168.1.1
p.s. I am able to access with direct cable to laptop...I meant to access it after router configuration
Hi, i also have bridge mode active in my Gx titanium 2122A and can't connect with PPPoe on TP-XZ000-G7, tried with TP-Linkrouter and er605 with vlan 100. if anyone can confirm if disabling bridge mode could fix it?
