XZ000-G7 worked just fine for me on Airtel by pasting SN and changing from HEX to ASCII+HEX (just 2 options). The main benefit was that it allowed me to get IPv6 working properly. I tried both transparent and VLAN tag modes and both of them worked. Finally settled with transparent mode to avoid extra processing and leaving SIP as an option for later.
Overall, it went pretty smooth for my first time replacing ISP provided CPE completely.
The provided Genexis T-2122A
ONT (absolute garbage) came preconfigured without IPv6 and even on bridge mode w/ PPPoE on my
router, I was unable to get DHCPv6 working at all - I assume there was some sort of VLAN tagging, PPPoE relay, or plain firewall blocking DHCPv6 somehow. It had to be the Genexis as I tried both OpenWRT and stock router firmware. That firmware worked just fine for IPv6 on ZTE ONT. It's really unfortunate that
Nokia/ZTE ONTs are getting swapped out for misconfigured Genexis junk now.
Without IPv6, I knew I was risking getting stuck behind CG-NAT hell and surprisingly I did get a CG-NAT IP for the first time today.
