Huawei E1750 3G USB modem not working with BSNL Mobile SIM card.
  • Thread starter Thread starter Sahyadri
  • Replies Replies 113
  • Views Views 88,304
I have mentioned it in my post itself.
Please check the link for price.
Hello,
I am Chandan Somani,
I also had same problem and also tried everything u tried
I have purchased same device from Leoxsys, Banglore.
what u did now what price u purchased and from whom?
kindly reply
Have you not been able to connect via E1750 even once ?If so,then are you seeing Airtel/BSNL 3G connection(which ever SIM you are using) under "Network and Sharing Center" ?
Yes, I can see "CellOne" Mobile Broadband Connection in "Network and Sharing Center" but am not able to connect to Internet through there also ( have to input APN there "bsnlnet" also tried "gprswest.cellone.in".
Is this problem related to E1750 or bsnl sim ?Becoz i want to buy this modem from ebay, but after reading this thread now i am confused.
^^ i suggest you refrain from buying it from ebay, as of now. i think you should contact, bsnl guys for settings. another thing is that i kind of do not trust the seller of the particular modem. try going on airtel sim or other operators just to confirm that you are not cheated by the seller. if problem still persists, after you get settings from bsnl, please give up bsnl.
I'm also facing same problem. Have 3g Sim, and when trying to connect via bsnlnet gives 619 and 628 error :|, btw internet works fine on Nokia 5800 .
So it's sure that it is a problem @ BSNL end regarding some configuration.We need to get in touch with prober person in BSNL.
@ganesh177
@chandansomani
@kunalgautam
Can you contact the persons mentioned on the link below
They are from Pune Office I guess Bajirao Rd.
Maharashtra Telecom Circle
I think Vishwanath Kendurkar DGM (Mobile-VAS) can be of some help.
