Sorry, Bit late to get into home.I think there might be something wrong with configuration.
I assume you connected by wire to your MAC
How to check Ethernet connection speed on your Mac - Austin MacWorks
If your Mac's connection to the Internet seems slow, there's an easy way you can check the speed of your Ethernet connectionaustinmacworks.com
What is your link speed?
Also,
go to Router UI:
1. Click on Network Map
2. Click on router logo thingy
3. Scroll down and youll see "Ethernet Status". Send pic of that
Here are the screenshots
Seems like there is no issue in that...
Internet speed reduced after installing this router.. Now getting 80Mbps download and 50 Mbps upload. Formerly it was 100+ both on download and upload..
Its 80-90 download and 30-60 upload.
Any idea why it happened?
I am using LAN 3 port of the ONT. Do i have to use LAN 1 port? Does it make any difference?
Thanks
