JIO WiFi Calling not working with my broadband
Pune
Hi,
I am using Samsung Galaxy S10+ with Jio & Airtel SIMs. WiFi Calling gets enabled for both my SIM everywhere except when connected to my home broadband.
At my home broadband, which is Airtel broadband franchise, Airtel WiFi calling works but Jio WiFi calling does not work.
During my experiment, I connected my laptop with WiFi and created a hotspot and connected my mobile with that network. This time both SIMs enabled with WiFi calling.
Any suggestions.
Hi,
I am using Digisol router DG-GR1310. I am not sure how to modify DNS. Here are the existing network info
NetWork Info
Default Gateway144.48.176.50
Subnet Mask255.255.255.255
Primary DNS Server8.8.8.8
Spare DNS Server4.2.2.2
@tani facing exactly the same issue after switching my broadband connection. I'm usingSamsung M31 and best part is @jio says this phone isn't supported for vowifi.
Were u able to resolve the issue. Let me know how to fix this problem.
Im using samsung Note 10 and facing the same issue.. unable to connect volte over wifi.. tried all provided dns entries but none helped. Kindly suggest as my regular airtel signals are way pooor on ground floor.
The problem with jio is you need to be in place where jio network is available and you are connected to wifi then only wifi calling gets enabled. Or if you can move out of jio network and within few minutes come within range of your wifi it will connect. airtel connect to vowifi without need to be in its network but you cant receive sms
Upvote 3
